All my RX path questions
I am a lineman for the county.
What dbi is considered as high, medium and low gain antennas
There isn't a standard. Decibels is a reference between two levels, so high, medium and low are subjective.
For radio/antennas, the reference is either a 1/4 wave antenna or a dipole in free space.
tldr; It depends entirely on what YOU are comparing it to.
prcguy
Zero dBi gain is 2.14dB less than a dipole which would make it -2.12dBd gain. I would consider an antenna with less than 0dBi gain up to about 5dBi gain a low gain antenna with 5dBi being less than 3dBd gain. From 5dBi to about 8dBi might be medium gain and maybe 9dBi and up might be considered high gain being over 7dBd.
Bonkk083
Union, SC
What's the difference between 1/4 and 1/2 wave
Bonkk083
Union, SC
I see some antennas 5, 6, 7, 8 dbi, but I might go with a 6 or 7 but I'm unsure about the 8
ladn
Remember, there is no free lunch. All that antenna gain comes at a price which includes:
  • Size
  • Acquisition cost ($$$)
  • Bandwidth
  • Radiation/reception pattern
And, whatever "gain" the antenna provides can be easily mitigated by feedline losses.
Choose wisely!
Bonkk083
Union, SC
  • Size
  • Bandwidth
Choose wisely!
I'm planning on using 50 feet of Lmr-400, The 8 dbi Laird omni is $160 plus $30 for the mounting hardware
Bonkk083
Union, SC
There are a lot of good used antennas for much less than that new Laird. I recently picked up a pair of Antenna Specialists 15ft long 8.5dBd omnis with adjustable downtilt for $50 each. Check eBay and local Han swap meets, surplus 800 antennas are usually dumped cheap.
This is my results for line of sight
jwt873
Woodlands, Manitoba
A quarter wave at 850 MHz is about 3.3 inches long.. A half wave is twice that at 6.6 inches. I'm not sure what you mean about avoiding obstacles.
Bonkk083
Union, SC
  • No Ground plane is required for 1/2 wave antenna while its required for 1/4 wave antenna.
  • More energy will be transmitted horizontally in 1/2 wave antenna compared to 1/4 wave antenna.
  • Half wave antenna will be taller is size and would therefore be able to avoid more obstacles than quarter wave antenna.
jwt873
Woodlands, Manitoba
OK, looking at the link Whiskey3JMC posted. Yes, all the above is correct.
On the obstacles.. Is your installation going to be that tight that an extra 3 inches in length is going to make a difference?
Bonkk083
Union, SC
It's a outdoor base the 1/2 wave antenna I saw is 4.85 dbd 57" and a 1/4 was 6 dbd 65"
jwt873
Woodlands, Manitoba
At 57 and 65 inches, those aren't half and quarter wave antennas. What they do is stack several quarter and/or half wave antennas on top of each other. What that does is increase the gain by directing the energy towards the horizon. This is known as a collinear antenna.
Since the Decibel scale is logarithmic and not linear, the difference between 6 dBd and 4.8 dBd would be negligible.
