What frequencies do you want to receive? I took a look at Bruce Childs antennas and he specifies that they have a 4% bandwidth, that's usually when they are 3dB down. One antenna looks like this:
Base 8009 800-850 Mhz, 9 dbd, N female
4% at 800MHz are 30MHz.
Antenna gain needed can be very local even at 150MHz. If I move my VHF antenna 3-4 meters, 10ft, the signal change dramatically while I move it, but then I do not have line of sight to the transmit antenna that will make it sensitive to where I locate the receive antenna. Some sites will be better and others worse depending of their directions and where I have my antenna. Sometimes one of my UHF antennas will receive a VHF signal better than the VHF antenna due to its better position for that specific site.
/Ubbe
