All systems turned off 436HP
amickey1979
Easton, MD
I have accidentally turned off all systems I was monitoring and I can figure out how to turn them back on. I have tried turning the systems back on but the scanner does nothing except say "Scan Mode. Nothing to scan. Any help would be appreciated. I have tried searching the threads to now avail.
Thanks in Advance
AC2OY
Belleville,New Jersey
Menu manage,favorites lists,monitor and download on? Did you assign quick keys? I'll be honist I have no clue about that quick key thing I just turn them on in sentinel and use avoid or if I hate what's in it I just go in the software and turn off or remove stuff.
davenlr
North Little Rock, Ar
Thanks in Advance
Menu -> SET SCAN SELECTION -> SELECT LISTS TO MONITOR
*Turn at least ONE of them on*
Menu -> SELECT SERVICE TYPES -> Turn the ones you want to listen to ON
That should get you scanning. If not, plug the scanner into your computer, and in Sentinal, click write to scanner, and check Force full database upload.
JoeyC
Senior Member
San Diego, CA
You will still have the "Scan Mode. Nothing to scan" issue even if your system is ON in the scanner if all of the DEPT and SITES are OFF. Make sure that at least one DEPT is ON in the system(s) you are trying to listen to.
Scannerham62
Surfside Beach, SC
Press menu, then select "set scan selection", then "manage quick key status", the select "system quick key", then select the favorite list where you turned all the systems off, "set quick key status" will appear.
You must turn "ON" at least one system.
