All Uniden Rebanding Updates Released (Including BR330T)
whacker
Buchanan, MI, USA
I know I'm a little behind on the rebanding thing, but it hasn't happened yet in my locale (Michigan MPSCS-southwest part of the state), so I'm wondering: Should one hold off applying the rebanding update to his radio, or does applying it simply enable you to set everything up again, programming-wise, when the time comes, and not actually change anything until then? Further, the rebanding update is a totally separate thing from the firmware updates (which I'm up on), correct? BCD396T is the radio.
Rabbitiswise
S.E. Michigan
Here you go:
BC796D
32bit Vista
USB-Serial Data Cable
All Drivers Up to Date
All bps all set the same(tried 9600 and 57600)
Same Response.
HELP.
chgomonitor
Silent Key
Chicago
296D Rebanded 3600 baud P25/Analog System
Okay, thanks for the update on the 296D Paul, you Da Man!
Got the new VUP and firmware update. The first time I tried it didn't work - the scanner display wouldn't blank out. The second time (with the batteries out) worked fine.
I've re-programmed (the wife's) radio on the systems she usually listens to. I'm listening to Northwest Central Dispatch out here in suburban Chicagoland. It's a dual mode - analog & P25 Motorola Type 2 system with a 3600 baud control channel.
It is working in both ID scan and search, but not quite as well as before. It's missing some transmissions, I'd guess maybe 15 or 20 percent more than what it missed before.
I've got an identical setup running on the desk with my 396 while testing. I can tell when the 296D is missing, the display begins to strobe between the normal control channel tracking display and ID activity display, but the squelch doesn't open.
Also - in order to really get the radio working at all on this system I have to use Control Channel only mode. If I don't it doesn't seem to be tracking at all.
I've tried every combination of settings I can think of, the only thing which makes a difference is turning the control channel only mode on/off.
Any hidden menus I should try dickering with?
So, a whole better than what I had before (nothing), but not exactly perfect. I do thank all the good folks at Uniden for the efforts with supporting this older radio, anyway. My wife loves her 296D.
Happy Scanning! - Ted
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
I am wondering the same thing myself. If I install the update, will the current 866-868 MHz section still be usable as before? I don't want to make a mistake, and have my 796D become a useless paperweight.
73s
Ron
davidmc36
South East Ontario
73s
Ron
I put the update on my 296 and everything still works fine. All it does is add the ability to put in the custom band plans if you need them. All your other settings are still there and non-rebanded systems still work as they did.
bluefox2163
i am continually getting an error message ,what could be wrong it wont download,can anyone help? thanks!
bluefox2163
just like like the message rabbitwise post two above mine it says communications error i am tryin to download version 2.007 in the bc796d>first but it is not workin
davidmc36
South East Ontario
For some reason you do not have the comm port set up right or do not have the correct one selected in the update software. Can you look in device manager to seee for sure which comm port you should be using? I assume you are using a USB converter like rabbit is? You could try uninstalling the comm port and starting over, being sure to install the drivers first, then plug in the converter. I find it helpful sometimes to get the UASD or equivalent software working first and confirm what comm port to use. And remember to shut down any other software too, you can't have two programs trying to use the same comm port. Maybe even reboot the computer after shutting down the other software, making sure it is not set to auto-start with Windows.
dave3825
Suffolk County NY
what is usad and how do I access it on my computer?
UASD is software made by uniden for programming your scanner. It like Butel, Bc tool and freescan.
You can only access UASD if you install it. I am not sure what scanners its compatible with. It is not part of windows.
Rabbitiswise
S.E. Michigan
Well I am still getting the same error. I have had the computer, software, and scanner all at the same bps. and every bps offered.
When I use the programing softer were and go to virtual mode. It says error but I am getting some control, like hitting the menu button.
Thought it was the cable issue. Elimanted that by buying a new one. One that is Vista compatable.
Still no luck.
Starting to lose hair and getting bruise on fore head.
Rabbitiswise
S.E. Michigan
Well unfortunely I have tried everything under the sun, moon, and my arse.
For some reason I am unable to read or send to my scanner any programming. I have 2 demo and the factory software, and there is no contacting.
I know for a fact that the System is recognizing where its at...if i move from com4 to com5 its sees it and only offers where its at.
MarkWestin
Caribou, Maine
Rabitwise, Do you have or have you tried a null modem adapter in your cable? If you needed one, this could explain what you are seeing. They should only cost a few dollars. It might be worth it to find out if this is your problem.
Rabbitiswise
S.E. Michigan
What is that suppose to do?
Plus will it work with Vista?
