I've recently put together an AllStar node using a Raspberry Pi 2 with HamVoip distro, a DMK-URI and a Baofeng UV-82 (for now) My node shows up at the Allstarlink as being connects (7-8 days now) and I think I'm communicating between the radio and the Raspberry Pi. I receive an audio announcement of the time at the top of the hour (on my HT that I use to in conjunction with my node radio) and when I enter DTMF commands get a courtesy tone back from the node. (If I disconnect the UV-82 from the Pi, no courtesy tone) I also see the transmit light illuminate on the URI. However even though I enter a node number via a DTMF command (e.g. *73 2560 for WIN System) I also can't get it to announce the time ( *81 command) Thinking I had a port forwarding issue, I placed the Raspberry Pi's static IP address into a DMZ via my router but still no go. I've also tried using two different HTs to communicate with my node radio suspecting a DTMF accuracy problem. If I issue a *70 DTMF command, I do get a CW ID return. Any suggestions?
