Along With Leaving A Channel Or Not
mipsyop
Sauk Rapids, MN
Once You Program In A "dummy" Frequency Such As 1300 Between Your Cc's, Can You Lock It Out So As To Make The Scanner Faster, Or Will The Speed Difference Be Insignificant Enough As To Warrant Just Leaving It Alone? Any Ideas Are Appreciated.
mikey60
Oakland County Michigan
If you lock it out, it's the same as not being there as far as the scanner is concerned. They need to be active, FM mode frequencies (no CTCSS or DCS tone).
Mike
torontokris
Toronto Canada
But doesnt locking it out effect the CC monitoring (negating the reason for having the gap there)?
Maybe im wrong.
