giant22000
- Joined
- Jun 5, 2011
- Messages
- 78
My goal is to use Proscan and stream audio from my phone to my car via bluetooth. Everything is working great except the audio sync problem with alpha tags. There is no longer a sync issues with the latest Proscan version using the webserver. Problem with using the webserver is the alpha tags do not display on my infotainment screen in my car. When using VLC and network streaming via m3u alpha tags display properly no problem but the sync issues are present by about 4-5 seconds. I believe the problem is with VLC as it will not let you set a custom network cache in the mobile app as it only allows you to set preset values with the "lowest latency" being 4 seconds.
With this said has anyone been able to get any of the following working as these would be acceptable solutions for what I'm trying to accomplish:
1. Safari display alpha tags when bluetoothed to car infotainment.
2. Able to reduce VLC network cache below preset values in mobile app.
3. Possibly using a different app with more granular control.
If anyone hasn't been able to accomplish this, would a feature request to delay alpha tags within the Proscan app be plausible? Thanks.
