Can someone give me information on what Alpha Tags are? I saw this next to a feed this morning and I have never seen this before.
Alpha tags are the "friendly names" (or are supposed to be) for frequencies and talkgroups programmed in your scanner.
For instance, i might have a talkgroup 1024 programmed in my scanner for a particular system, and depending on the scanner I'm using I may be able to set up a "pretty" name for it such as "Podunk PD TAC 1", so that when that talkgroup becomes active, "Podunk PD TAC" is displayed instead of the talkgroup 1024. Or I might have "JEFFCO S.O." programmed in as an alpha tag description for frequency 39.88 so that when 39.88 becomes active I see "JEFFCO S.O." on the screen instead of [or in conjunction with] 39.88.
This is extendable to live audio feeds (a) if the feed provider's scanner supports alpha tags, (b) if the feed provider has a supported scanner that works with the feed software to send the alpha tag information and (c) if the listener is using Winamp, Itunes, or some other player that supports Alpha Tags.
The web player will not display alpha tags. On my feed, which sends alpha tags, if somebody listens to it using Winamp they will see the "friendly name" for talkgroups and frequencies when they become active so that they know what agency is actually talking.
On a feed that does not provide alpha tag information, the listener may not know what agency is actually talking.
Mike
