Aluminum Body F150 NMO Mount in Roof
CopperWhopper67
What is everyone's thoughts on using a step bit instead of a hole saw?
Also a tad off topic but just because it was brought up:
I have a brother in the Shingle Springs area.
Shingle Springs is my hometown! I never thought I would see it named on the forums. Small world I guess.
I am a lineman for the county.
I know people have done it. I think my brother in law did one of his trucks with a step bit. It can absolutely work if you are super careful. You need to be 100% sure you stop at the 3/4" point and go no further. You also need to be 100% sure the point of the bit doesn't go through the headliner or anything else. The aluminum used on these trucks is a very hard alloy, so images of it tearing like a beer can aren't likely to come true, unless you go way too fast and with too much pressure.
The reason I'd never use one is that if you screw up, the cost of fixing it is going to be way more than the cost of just getting the right tool for the job. It is way too easy to screw up with a step bit, and kind of hard to screw up with the purpose built hole saws.
Your truck, your choice. As Clint Eastwood said "Do you feel lucky?"
AK9R
Super Moderator
Central Indiana
When I have used step bits, I put some paint on the step just above the size that I want. As the drill is spinning, you can see how close you are getting to the desired size.
You are correct that you need to be careful. Keep the bit perpendicular to the surface you are drilling to minimize tear-out. Pause after each step so you can assess your progress.
Good point about the cost of fixing the roof of a 50 to 90 thousand dollar truck vs. the cost of the proper hole saw.
6079smithw
Near the Biggest Little City
I had a friend that did installs for a town in CT; radios, light bars, etc. who swore by this Ripley hole saw.
I bought one on his advice and have had excellent results. It ain't cheap ($44.00 IIRC) but works as advertised
especially when you can't drop a headliner.
As my late Dad would say: "If you don't have time to do it right, where will you find the time to do it over?"
AK9R
Super Moderator
Central Indiana
I used to work for a company that never had time to do it right. But, they always found time, usually by stressing the employees, to do it over.
The Ripley hole saws are the gold standard. I've done fine with my Laird hole saw, but I'd love to find one of those at a decent price. Last one I found came with the 1-1/4 for the low band whips, and it was priced pretty high.
wwhitby
Autauga County, Alabama
I learned a very long time ago to always use the right tool for the job. A 3/4 hole saw made for NMO mounts is more expensive, but IMHO, its worth it.
My late Dad always used to tell me that if you do it right the first time, you don't have to do it again. And even as a smart-mouth teenager, I knew he was right. I still give that advice out to people.
BTW, I found the Ripley HSK-19 hole saw available online for $38.99. That's not too bad. I'm planning on a new truck next year, and, yes, I'm going to drill holes in the roof!
AK9R
Super Moderator
Central Indiana
AK9R
Super Moderator
Central Indiana
Google it, man.
BTW, Tech Tool Supply has all sorts of cool stuff for low-voltage installers.
Google it, man.
I ordered one earlier today. Had trouble finding it via google. Kept finding higher prices.
wwhitby
Google it, man.
Sorry, I should have posted a link in my original post.
The company that AK9R shared was the same on that I found.
Knowing how I am, I'll probably order it just as soon as the price goes up! :D
krokus
Southeastern Michigan
I noticed the description of the HSK-19 says the shoulder will score the paint, for better grounding. My thought was that I want to not leave bare metal on the weather side of the mount, to avoid future corrosion. Am I missing an advantage to the scoring?
6079smithw
The shoulder is designed to remove a small amount of paint around the hole. The mounting flange nut has a groove on
one side with a O-ring. The ring is a bit larger diameter than the unpainted surface and is installed facing downward.
This acts as a moisture seal for the hole and the unpainted surface. This feature is one reason why the saw is kinda costly.
I've done a bunch of installs with this tool over the years and have yet to lose a ground from leaks or corrosion. $$ well spent.
KC8ONR
bridgeport
From my experience of using this saw i have never noticed any scoring of the paint on the outside, then again I don't use any pressure at all , I let the saw do the work. I do use a small piece of emery cloth to clean the hole a bit , I also sand the underside where the ground will be. Most of the ground is on the underside anyway
AK9R
Super Moderator
Central Indiana
With the Larsen NMOs that I've installed on my personal vehicles, making a good ground on the underside seems more important than grounding on the top side. Of course, you have to have access to the underside. If working from the top side, I suppose a small strip of sand paper wrapped around an index finder would do the trick.
krokus
The underside was what I understood to be the important part, with the topside mainly being weather seal. I have used primer, or touch-up, along the rim of the new hole. Also preferred to use some type coating on the underside connection, the prevent oxidation. (Such as small amount of anti-seize, or battery terminal treatment.) That might be the Navy conditioning coming through, as salt eats everything it can.
