For your SDS100, or SDS200, you can create a system in Sentinel:
In Sentinel:
Click on the Plus sign (
+) by USA in the main database section of Sentinel.
Scroll down through the list of states until you get to Texas.
Click on the Plus sign by Texas
Scroll down until you get to Brazoria County, & click the Plus Sign by Brazoria.
After expanding the Brazoria folder, click on the County Systems folder to expand it as well.
Under the County Systems folder, click on the item labeled simply as Brazoria,
In the list of departments under 'Brazoria', you'll see Alvin Independent School District.
<Right><Click> on it.
Choose the item labeled Append to Favorites list.
Sentinel will then ask where to append it. You can send it either to an existing Favorites list, or create a new one.
(I'm sending it to a list that I use for doing screenshots when answering an inquiry.)
Select the list that you chose (or a new one) and open that list in the Favorites list Editor.
You see that when I appended it, it was done as a conventional system,
We're going to create an OFT system for this, but by appending the conventional channels, I've also brought over the location information.
Click the Green Plus sign in the Favorites editor to create a new system.
Choose DMR One Frequency and give it a name.
While holding on the system name (Alvin ISD Buses) click on the Departments tab & hit the green plus sign there, to add a Department for the talkgroups.
Now, enter the talkgroups as shown in the database. Use the Plus sign when the Department is selected to add the channels for the TGIDs.
Next, select the System's name again, and click on the tab labeled Sites.
Create a site for each frequency.
Enter the frequency & color code for each 'site'
If you are putting this system into a Favorites list where, on occasion, you might use Location Control, then add the location details to the Department as well as each frequency. That's why I first appended these channels as conventional, so that location data is copied into the list being edited, and you can cut and paste the data,
This same information would need to be entered into the department (for the buses) as well as the Sites (the two frequencies).
After getting it set up as an OFT system, I deleted the Conventional system as it is no longer needed. Note that, in an OFT system, you can specify the Slot being used (this is noted in the database), but that is not necessary since separate talkgroups are specified. There are some agencies that use the same talkgroup, but specify, for example, Police on Slot 1, and Fire on Slot 2.
I have exported the system into an *.hpe file. It is 'zipped' (compressed) because that is required to attach a file to a Forums post. Save Allen_ISD to your PC. Extract the hpe file using Windows Explorer (also called File Explorer) and import the hpe file into Sentinel and add to the Favorites list of your choice. (The Import link is under the drop-down File menu in Sentinel.)
