No, I'm not crazy and 4 or the 5 voices inside my head agree with me.
OK, I hope someone on this forum can help me with a problem I have. I have a new pick-up truck that has an AM/FM radio that works great.
Here is the problem. I also have a large slide-in type truck camper that sets in the bed of the truck, but also hangs out over the cab near the factory fender antenna. It looks something like this:
http://www.lassenrv.com/host camper.jpg
When I put the camper on the truck, my FM reception does not change, but my AM reception is almost completely lost. It’s is at best 10% - 15% of normal. The camper does not actually touch the camper, but the tip of the antenna is about 6” away. The camper exterior is aluminum siding.
I tried putting one of those little rubber ducky short antennas, but it didn’t help.
Now here is the weird part. If I grab the antenna with my hand, the AM reception goes back to 100% normal. Now if I had a really long arm I could ride down the road holding the antenna and everything would be fine, but my arm just ain’t long enough.
To make things even weirder, many years ago when I first noticed the reception improvement when I grabbed the antenna, I tried a few experiments.
I took a short piece of #18 insulated wire and put an alligator clip on the end. I then attached the alligator clip to the stainless steel antenna. I first tried attaching the other end of the wire to ground. That didn’t work. I then tried putting a couple of different resistors I had laying around in the circuit to ground. That didn’t work either.
But then I put a little capacitor I had laying around in the circuit and the AM reception improved to almost normal. In other words, I had an alligator clip on the end of the antenna, then a wire from the alligator clip to the capacitor and then a wire from the capacitor to the truck ground.
Does any of this make any sense? Why would that work? Why would me just grabbing the antenna make the AM reception almost normal?
Anyway, what I’m getting around to is that was many years ago and I don’t have that little capacitor any longer. I don’t remember the rating on it but it seems like it was 4,700 micro farad and 250 VAC? But I could be totally wrong on that. Maybe it was 4.7 micro farads. I just can’t remember.
I’m going down to my local Radio Shack sometime this week and pick up a couple of capacitors and see if I can reproduce my results from 8 or 9 years ago. Any thoughts on this or advice would be greatly appreciated. I am a gear head by trade and struggled to get through Electric Circuits 101 & 102.
HW
HW
