Am I about to Brick my mobile
PCTEK
Northern California, USA
Hello. I just read my Moto CDM-1550LS+ using CPS version 06.12.02. It shows the firmware version of the radio as: R05.10.02 I've saved a copy of the this original code plug. If I write to the radio with my CPS version, will it "brick" the radio? Also, the radio shows that I can program GMRS frequencies in Wideband (25khz). If I write to the radio using my CPS, will this require that I get an entitlement wavier? odd that FRS is narrowband and GMRS is wideband. oh well. Thank you for you help.
Tech21
No, it shouldn't brick the radio. After all you were able to read it just fine with your CPS version.
ten13
ten13
My rule of thumb with the CDMs is, no matter what your doing...reprogramming the whole radio, changing one channel, one CTCSS, etc.... always READ the radio first, no matter how many times you've programmed it before, and even if you have saved code plugs.
Sometimes these radios get a little "off-kilter" for one reason or another (the cable or computer you're using, etc), and most of the time it's correctable. If you can't read the radio, and there's a problem, at least the radio isn't partially or fully DOA from trying to program it.
N1GTL
CT
The FIRMWARE and CPS versions do not need to match. It's rare when that does happen.
PCTEK
Yes, I read the radio before doing anything and saved that codeplug to a safe place. I was able to write to the radio using my version of CPS. But... I have 8 channels programmed in zone 1. When the radio starts, it shows me what is in channel 1, but the up and down buttons do not raise or lower the channel. I can't find any button programming other than P1, P2, P3 and P4. Am I missing a setting?
My apologies to the readers here who are frustrated by newbie questions...
brndnstffrd
CT
What is the model number that the programming software shows? Does it match the model number on the radio brick?
PCTEK
The model number shown in the CPS as well as on the factory label match: M25RHF9DP5A. I purchased this radio from Sunny Communications and they have been a good reseller
Ant9270
The Green Weenie
Did you place the channels you programmed into your zone? If you didn’t, it will only stay on what is defaulted in the zone.
