Hopefully this is general enough of this forum. I have a Uniden SDS100 and am exploring railroad frequencies. I set up a favorite with all the Florida railroad frequencies loaded thru Proscan from the RR database. I am hearing some conversations even on very weak signals. I'm hoping when I get a better antenna I'll get better signals. However, on a couple of channels, the scan halts and all I hear is noise. It's not a particularly weak signal as far as I can tell with an RSSI of about 84. I can hear conversations on channels with worse RSSIs. One of the channels this happens on is 160.8000 MHz. I've tried different mods and different filters.
Is this just someone leaving the mic "keyed"? Is this like a constant information transmission but the signal is too weak for me to hear the audio? I've poked around the wiki, but of course part of the problem is when you're new, you don't even know what words to use in a search.
See video in hyperlink ------>160.800 MHz
