LOL,Good work @u2brent!
The truth is, I googled it, and that was the best result/explanation.
Well, that's what I remember, too, but every time I hear people double, one of them is understandable and the other is not at all, whether it's two aircraft or aircraft and ground. It may be theoretically possible, but the right conditions (signal strengths?) for it to happen don't seem to occur often. Anyone else actually hear it in practice? (Talking AM full-carrier here, not SSB here).Learning time... Who can answer why are most ATC comms still in AM?
FM has a capture effect..... if a plane captures the frequency and is stronger, another one will not be able to be heard. That doesn't happen in AM.... the signal may have a chance to be heard.
Frequency tolerance and drift.So why not SSB?
I don't know about that. Stability has improved incredibly in the last few decades. Sufficient accuracy at VHF is not that expensive to accomplish, especially if you require GPS while you're at it. There's also ACSB's pilot tone approach to freq alignment (OT: anyone know if there were reasons other than marketing that it died in the US LMR market?).Frequency tolerance and drift.So why not SSB?
It's not used for air traffic control in the US but there are other users.I am not aware of any facilities in the US that are using an 8.33 center frequency, am I correct that EU is where this has mainly been rolled ot?
As mentioned, AM does not have the capture effect. So when there are multiple aircraft transmitting at once, likely only 1 will be intelligible, but ATC will know that more than one aircraft keyed up. So ATC will handle the intelligible call, & once they finish up with that they will often ask for the other aircraft to identify & repeat their comms.Well, that's what I remember, too, but every time I hear people double, one of them is understandable and the other is not at all, whether it's two aircraft or aircraft and ground. It may be theoretically possible, but the right conditions (signal strengths?) for it to happen don't seem to occur often. Anyone else actually hear it in practice? (Talking AM full-carrier here, not SSB here).
This series is what we used for the few VHF freqs my ship utilized, which was basically for IAD/guard. (The UHF freqs were with AN/WSC-3 models.)For the record, here are photos of the actual UHF air band radios we have used in ATC in Canada since the late 1970s. They were also available in VHF models, although in Canada we did not use the AM variant. The ITT GRT-22 exciter (10W nominal) and the GRR-24 receiver. There was also a 100W RF amplifier available. (Photos "borrowed" from online sources, these ones have seen better days!)
View attachment 121949View attachment 121950
