Same here Jim. No matter where you are, when nightfall hits your area, the MW band opens up to distant stuff sometimes over 1000 miles, which obviously provides one with that much more programming (except for the gobs of stations running Coast To Coast AM)
Every night, I listen to stations, a couple are almost 800 miles away, to stuff that isn't playing here near SFO. I very rarely listen to the locals except in the truck.
Matter of fact, I was pleasantly surprised to read a bunch of guys in the Antique Radio Forum like to do MWDX because it is the distant stations that have the nostalgic and oldies type music they're after to play on their old radios. That is neat.
Car radios used to be excellent MWDX machines.
Hmm, the stock radio in my '12 Mustang is a DX monster, even with that nubbly little antenna. Go figure.There, I fixed that for you
Most modern car AM/FM radios I've used are horrible on AM. They are mostly designed for XM/FM use and AM is an afterthought. AM sensitivity and noise rejection are horrible on the ones I've used.
Many years ago though, car stereos were quite the acceptable AM receiver.
You need to get the GM/Delco car radios for top performance.
The DX-398 is a good performer on MW (although I don't use mine for MWDX, for some reason -- probaby because of the sound. I prefer my Superadios and a couple other models of AM radios).
The 398 runs the MW signals through the entire chain of RF and IF amp FETs before hitting the IF chip, so there is a lot of gain and filtering.
The loopstick may be the radio's main 'limitation' for MW DX. The loopstick isn't monstrous, but it does run the length of the top of the radio, probably between 100-120mm.
Try using an external loop with it, Jim, and you may get some extra stations on it.
I agree on the ability of some car radios to DX. I had an old 1970 Ford Philco car radio that was excellent. That radio seemed to have gain to burn. Excellent sound, too!
