I'm looking for a way to get AM reception inside my house. I'm approx 60 miles from the nearest AM station with many mountain-tops between me and the transmitter. I also have a few "noise" problems at my house. One being 4800 volt powerlines directly over my house . Another problem is my solar-electric power which uses two big DC to AC inverters that make lots of noise that ruins AM reception when 100 feet or closer.
I've got 80 acres of land and mountain-tops and have many choices to install out-door antenna.
My problem/question is this. I can park a car or truck 50 feet behind my house and get the AM station I want fine. All I'm looking to do is get a signal inside my house that is at least, as good.
Yeah, I could junk a car or truck next to my house and run wires from it's radio into the house to power inside speakers - but that seems a bit silly.
I've tried various radios including three versions of the GE Super Radio, a Tescun BCL-2000, a Grundig S-350, and a Kaito/Degen KA1103.
With antennas - I've tried several wire-wound loops, inside and outside. Also have installed an ENDFEDZ EF-SWL FED Receive long-wire outdoor antenna. The long-wire antenna has 40 feet of wire and a 9-1 transformer with a SO-239 connector. I have an adapter to convert to a F connection - then RG6 coax for 75 feet - then a 75 ohm transformer to hook to the radio. Co-ax is grounded via twin 6 foot ground rods.
The long-wire antenna via the two wires from the 75 ohm balun does little when both wires are hooked to the radio. Works better with only one wire hooked, and better yet with one wire plugged into the radio-ground terminal for SW/AM, and the other simply wrapped around the FM telescoping antenna.
Basically - none of radios see much improvement with any external antenna hooked and using the long-wire antenna adds quite a bit of noise. At present - with AM - my best inside-the-house reception is with my Kaito KA1103 and NO external antenna. It is not near as good though as any of my cars or trucks will get parked next to my house.
Any ideas on what else I can try?
Station I want is 810 WGY from Albany, New York.
