AM vs FM CB on scanner
FCVPI99
Rockford,IL
so CB band has always been AM .. now they have added FM .. whats that mean for scanning??? what FM do we use to scan the CB band? is it NFM or WFM?
and for CB use does FM Ch 1 hear AM Ch 1 and vice versa ?? or is it like 2 totally separate radios on the same freq where you can have a FM and AM convo happening at same time ?
nd5y
Wichita Falls, TX
NFM on CB is 1.8 kHz deviation.
NFM on LMR in the US (and probably what most scanners have) is 2.5 kHz deviaiton.
You can hear AM on FM and vice-versa but the audio will be distorted.
You can't receive two or more AM or FM signals on the same frequency at the same time and not have interference.
On FM if there are multiple signals at the same time and one signal is more than about 20 dB stonger than everything else then the the receiver should only hear the strong signal due to capture effect.
KD8DVR
Columbus, Ohio
The closest thing would be NFM.
AM and FM would interfere with each other and you'd be able to hear each other; but not necessarily understand each other.
