Amarillo, TX - Dust storm damages emergency radio system
sfd119
Equipment sustained no damage, but Easley-McPherson had to drive from Amarillo to Hartley County to put the system back online.
The equipment sustained no damage but it went offline? Am I missing something here??
R8000
Very Low Battery
My guess is the dust probably got inside and was sucked into equipment via cooling fans and caused havoc. Maybe things overheated until cleaned out by a tech.
mfn002
Bryan, Texas
Sounds likely. The storm probably clogged the cooling system and caused the equipment to automatically shut down to prevent overheating. They have a temperature sensor in them that will trigger a shutdown if it senses that the temperature has risen above a certain level.
DisasterGuy
Maryland Shore
Its been a few years since I left Texas. Any details on the system? I checked the DB for several areas of the panhandle and the only TRS I see is xcel energy.
