markking71
- Joined
- Jul 4, 2006
- Messages
- 16
I recently bought a bc246t and I am having problems getting UE's edacs trunking to work. any one listen to UE in missouri? I need HELP!
System Name: AmerenUE (East Central/South East MO)
County: 23 counties
System Type: EDACS Networked Standard
System Voice: Analog
Last Updated: [B]Changed Site-811[/B]
Hits: 2181
I have both St. Charles county, and St. Louis county sites in my Pro-97. They seem to both work fine. I just put all talkgoups in both banks and toggle which ever site I am closer to on.markking71 said:I recently bought a bc246t and I am having problems getting UE's edacs trunking to work. any one listen to UE in missouri? I need HELP!
What area are you in?markking71 said:I can't find any info on talkgroups in my area. I set the 246t to ID search, When there is activity (I hear on old scanner) the 246t doesn't do anything. I have arc246 software and it shows that the scanner is locking on the control freq. I'm starting to wonder if its actually an EDACS system.
Scroll down about half way on this page for three EDACS CC sounds. 5 Motorola sounds are directly above. http://www.kb9ukd.com/digital/markking71 said:I'm starting to wonder if its actually an EDACS system.
I wish I would have heard something. I only spent time enough to get off I-70 and go south on 54. My initial plan was to monitor it for a while. I had many delays getting started, and I was about two hours behind schedule.markking71 said:There are 3 simulcasted sites that cover a fairly large area, so the mexico site is pretty active. I still can't get it to track channels or even display a tg in "id search" mode. I have a few Columbia MO trunked systems programmed (MU and MO/COMM) and they work fine. But they are motorola systems.
I did program the 4 freqs as a SCAT system so it will ignore all the beeping and data bursts. Now I can at least listen without being too annoyed. Its quite interesting, one of the local radio or computer techs makes a lot of personal calls on the phone-patch. Now I really want to make it work right.
