American Electric Power (AEP) P25 WACN 92715
ralexander5
Mathis, Tx
FCC notifications were submitted by AEP for the following sites, suggesting they are ready to go.
woodson (throckmorton) - already confirmed online and in DB
tradewinds (san patricio) - already confirmed online and in DB
Refugio TX (Refugio) WPCB258 - not in DB -- probably should be on the lookout for it coming online
- likely 43.43 (in which 43.43 was reported as a neighbor of another TX site with a CC (at the time) of 854.9375
- so it is extremely likely that it is online, but the active CC may or may not be 854.9375
854.9375
855.1375
855.4375
855.8875
856.3875
857.4125
858.8625
If you're around the Refugio TX area, please attempt to confirm by using Pro96Com, DSDPlus or Unitrunker and checking to see if you find a site 43.43 on one of the freqs above. If you do, please gather/submit all details - (primary/alt ccs, nac, sysid, site ID, active frequencies seen, neighbors/peers and the frequencies associated with those neighbors/peers.
Mike
Took a drive to Refugio. Can confirm a CC of 855.9375 with NAC 02B. Neighbor reported is 57 (Tradewinds).
Site 57 is now reporting site 13 (probably Corpus Christi) and 43 as neighbors. 13 was showing isolated in DSDplus. Shows CC of 854.7875. Was unable to receive while in Corpus.
Info for Refugio has been submitted.
nd5y
Wichita Falls, TX
This morning Frederick, OK 1F9 041-041 is showing a new neighbor
1F8 093-093 855.28250
This frequency isn't even licensed and for some reason it's corrupting unitrunker and making it crash unless I delete the 1F8 system.
Good thing I back up (export) all my systems separately but that might not be enough.
I did this repeatedly and it is still trying to populate and delegate 1F8 or someting and crash.
I had something similar happen with one of the other western OK sites with a TX neighbor but it quit crashing because conditions haven't been good enought to receive it since then.
If I can't figure out what's going on and fix it then I will probably give up and stop providing updates.
firemantom26
Wintersville Ohio
Tom,
I stopped using Unitrunker a while back since I had the same problem. I find all my new sites using DSD-Plus-Fastlane.
I am working on finding more sites in WV that are online but need to be confirmed.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
It's also showing up as a neighbor on 1F9 013-013 Snyder OK.
The "fake" CC populated on the neighbor list changed twice. It went from 856.9125 to 854.8125
so it appears 1F8 093-093 Is Quanah, TX FCC Callsign WRMP753 (AMERICAN ELECTRIC POWER SERVICE CORPORATION).
Perhaps that site is just coming online, or isn't quite online yet. I think (and you can correct me if I'm wrong), UT does not differentiate between connected peers and failed/isolated peers. So it might actually be a failed/isolated peer for now with some oddball frequency and may not reflect properly on any neighbor lists until it is a connected peer. Just a thought.
Mike
nd5y
Wichita Falls, TX
Actually I misspelled the first frequency. It was really 855.8250.
Yeah this site just showed up this morning. It wasn't showing up on Frederick last night.
nd5y
Wichita Falls, TX
I don't know. I have never seen a site fail on a multi-site P25 system before.
AEP's EDACS system has several sites around here that have always shown "island" and have no neighbors.
DeaconHarry16
Beckley WV
Verification on 36.36 Ansted
855.2625 CC, 00-0341
856.4125 ACC, 00-0433
857.4125 ACC, 00-0513
Peers
05.05 Duo 858.7875, 00-0623
07.07 Hernshaw 855.1125 00-0329
19.19 Elkhurst? 855.7875 00-0383
31.31 Coal Fork 855.4125 00-0353
Compliments of Unitrunker on the Road
Harry
firemantom26
Wintersville Ohio
Peers
Harry
Good job Harry. Thank you for all your efforts and thank everyone else who has put good efforts and finding these sites.......
n8jsw
Ohio
As AEP rolls out the new system there were some that came online up here and were under a false C/C just until they were ready to fire it up for good and then the correct frequencies were put in and all was good
mtindor
OH/WV DB Admin
Recent Construction Notifications
  1. WQJP670 Snyder OK (Kiowa) - already confirmed online
  2. WRMP753 Qhanah TX (Hardeman)
  3. WPCN201 Menard TX (Menard) - 5253 Callan Lane
  4. WRMP757 Baird TX (Callahan)
  5. WPCB218 Rotan TX (Fisher) - already confirmed online
  6. WPCB218 Aspermont TX (Stonewall) - 5322 FM 2211
  7. WRKC328 Rule TX (Haskell) - already confirmed online
NOTE: For the above construction notifications, one or more may already be confirmed active and in the DB (I did not check). But one should expect all of the above sites to come online soon (based upon past history) if they aren't already online.
NOTE: Also a slew of updates to various SWEPCO licenses, modifying locations and/or frequency lineup. That would suggest they are starting to work on SWEPCO. If you look at the map below under the SWEPCO stuff, licensed not modified yet have a green dot, and licenses that have been updated have a black dot.
AEP P25 System Google Map
AEP P25 System RRDB
AEP P25 System Wiki
Mike
mtindor
OH/WV DB Admin
I submitted this one this morning.
Today the band isn't open much to the southwest so I can't tell if any of the others are on the air.
Thanks, Tom. I've added it to the DB. Great job! I appreciate it, and everyone down in the multiple states where you are sleuthing should appreciate it too.
Mike
nd5y
Wichita Falls, TX
I don't know if this was mentioned previously in this thread but I just noticed something.
All of the site NACs in my area are the same as the hexadecimal RFSS-Site Number.
I looked a a few random sites in the DB on all 5 of the system IDs and they are the same way.
mtindor
OH/WV DB Admin
Yeah, so far that has been the case for 100 percent of the submitted sites, throughout multiple states.
mike
