American Electric Power (AEP) P25 WACN 92715
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Still any thoughts on 7.7? Getting weak signal again with that. All frequencies match Poteau. However, we don't have any of the neighbor sites figured out except Leonard.
I didnt know you had confirmed this one before. But apparently it's confirmed now :)
10 - Leonard
19 - unsure - on an old Talahina site license (but that site had recently been deleted via FCC modification)
49 - Stigler
mtindor
OH/WV DB Admin
10 - Leonard
49 - Stigler
19 is likely going to be either Talihina (probably) or Idabel (possibly, although a little farther away)
Mike
mtindor
OH/WV DB Admin
And here is 15.15. I had to go up towards Vinita today for work.
Things are looking real good up in your neck of the woods now. Probably all you can do at this point is snatch updated neighbor lists for any sites you copy so that we can see if there are any new neighbors or if any unknown neighbor CC frequencies have changed.
Thanks for your efforts!
wx5uif
Broken Arrow, OK
I traveled down I40 today I got what looks like Stigler's info.
Neighbor: 92715.1F9-7.7
Neighbor: 92715.1F9-10.10 ; Leonard
Neighbor: 92715.1F9-19.19
Neighbor: 92715.1F9-23.23 ; Henryetta
Neighbor: 92715.1F9-28.28
Neighbor: 92715.1F9-32.32 ; Weleetka
Channel 0-277: 854.4625 SCC
Channel 0-375: 855.6875 CC
Channel 0-463: 856.7875 SCC
Site: 19.19
Channel 0-347: 855.3375 CC
Site: 28.28
Channel 0-311: 854.8875 CC
mtindor
OH/WV DB Admin
Site: 19.19
Site: 28.28
Great job! I suspect 19.19 is Talihina and that 28 is McAlester. Although 19.19 could conceivably be Idabel, even though it is significantly farther south. Too bad the CC on 19 hasn't changed since it was last reported as a peer of a site.
m
wx5uif
Broken Arrow, OK
Yeah, likely Talihina. I was able to lock on to the CC for 19.19 off and on for a few miles on my SDS200 while driving down I40. Signal was very weak, around -110 and less RSSI. However, I couldn't receive it with DSD with the antenna I have connected to it.
nd5y
Wichita Falls, TX
Band opening this morning. Finally confirmed Hobart and Chickasha, OK really exist.
Mike you can disregard the Blanchard info. I just noticed it was already in the db.
Also one of site 06's neighbor CCs that populated today was 27-27 855.1375.
I think that means the site numbers and other info in the wiki for sites 09 and 27 might be backwards but I have yet to decode those and figure it out. Before Unitrunker logged 09-09 854.7125 but that is licensed to the same site as 27-27 855.1375.
mtindor
OH/WV DB Admin
Somes for all interested in Texas
Extension request filed for completion of Texas portion
Bullet points:
  • Multi-year project upgrading EDACS 800 MHz system across 11 states to P25
  • Due to immensity of project, AEP is proceeding with the projeect by region
  • Bulk of Ohio is completed
  • Current focus on finishing up Oklahoma (within the original authorized 12-month period)
  • Texas will come next after Oklahoma
- more than 12 months will be required to complete Texas (thus filing for extension)
- will cut over by subregions within Texas
- cutover for each region will have to be done all at once (each subregion switches all sites to P25 at same time)
- 44 of 82 sites will require move to new location
- 14 of the 82 sites will be new sites
- Texas fully designed and funded
- see document for chart of two Texas subregions to come online by April 2021
- remember subregions will be cutover all at once (TCC2 and TNC3)
Remington12G
GØT AES?
I had to cancel my trip to Eastern KY due to the event I was attending was canceled. I will scan 800 on the way down 75 next week and see if any of those towers are online.
mtindor
OH/WV DB Admin
I guess we will just have to wait until sites 9 and 27 are copied directly. I don't think I have the sites backwards, but could be.
Mike
mtindor
OH/WV DB Admin
Obviously that extension I referenced in my previous post did not make any of WV (which has a significant amount of sites built out), Indiana / MI (pretty much built out), or the fact that there is a site online in VA. So they are obviously still doing things in other states, even though there is a "focus" on completing OK and starting on TX. So they very well could have sites online in other states despite the limited scope of discussion in the extension.
nd5y
Wichita Falls, TX
I wonder if they are doing South Texas first or last. So far nothing else has changed around me in a long time.
They might not be finished with Oklahoma yet.
There is a site near Snyder that is doesn't appear to exist but when it was EDACS I could receive it often.
I can't tell if the Cheyenne site is on line yet. It's too far away and so is it's neighbors.
mtindor
OH/WV DB Admin
That's a good question. I see a lot of FCC construction notification updates for MG / YO stuff, or at least have fairrly recently, for the Texas area. Not knowing Texas, I mostly ignored them -- but those various updates would probably lend some idea as to where the vast majority of TX work is taking place currently.
As for Snyder, do keep in mind that they have a pending application adding additional frequencies to that license. So you might not find Snyder P25 on any existing Snyder freqs.
854.0875 - added
854.3875 - added
855.1625
855.5625 - added
855.8875
856.2875
857.3375
857.4125 - added
858.4125 - added
So it is conceivable that if it is online it would be active with a CC on one of the new freqs (even though the license isn't approved yet). Just throwing that out there.
Mike
nd5y
Wichita Falls, TX
Yeah I know. I search the whole 851-861 band (among other things) usually every day.
Also it should show as a new neighbor on the surrounding sites and so far I haven't seen that.
mtindor
OH/WV DB Admin
Just between January 2020 and December 2020, there have been a signficant number of FCC notifications submitted by AEP for various areas, trunkekd and microwave licenses, in various states. None of these necessarily indicate that a site is fully online (especially MG licenses).
I separated out the MG (microwave) from the YO/YJ (trunked) licenses. I mainly included the MG (microwave) licenses to show that there has obviously been some activity (meaning work done) at various sites in various states even if they may not be online yet. Each category is in order though from January 2020 (top) to December 2020 (bottom). I left out Ohio stuff, and microwave in IN OH WV since I was primarily focusing on TX/OK.
And under the YO/YJ trunked licenses below, I specify online if they hae been personally confirmed AND if they are showing up as connected site peers but have not been directly confirmed by monitoring. I might have missed a few.
Point is, It's a good bet that a LOT of those YJ/YO licenses shown below are online, despite nobody ever having reported it.
Matador TS TX - MG - WRBW426
Memphis TS TX - MG - WRBW426
Bay City TX - MG - WNTX629
Laredo TS TX - MG - WQKP320
Laredo N TS TX - MG - WQKP320
El Campo TX - MG - WRBY607
Pawhuska OK - MG - WQBM394
Tesla Station POP TX - MG - WQME636
Bartlesville OK - MG - WQBM395
Pawhuska OK - MG - WQBM395
Quanah TS TX - MG - WQEI763
Cottonwood ETT TX - MG - WRCR649
Dickens TS TX - MG - WRCR650
Memphis TS TX - MG - WRCR693
Cisco TS TX - MG - WRCR704
Albany TS TX - MG - WRCR704
Aspermont TX - MG - WRCR708
Rule TX - MG - WRCR708
Memphis TS TX - MG - WRCR792
Shamrock TS TX - MG - WRCR792
Turkey TS TX - MG - WRCR792
Clarendon TS TX - MG - WRCR792
Wellington TS TX - MG - WRCR792
Lon Hill TS TX - MG - WQJF963
Concordia TS TX - MG - WQJF963
Grissom Station TX - MG - WNEV787
Beeville TS TX - MG - WNEV787
Wellington TX - MG - WRCT552
Quanah TX - MG - WRCZ956
Rotan TS TX - MG - WRCZ973
Eagle Pass TX - MG - WNEF600
Turkey TX - MG - WRDA906
Woodson TX - MG - WRDB601
Memphis TX - MG - WRDB692
Eagle Pass TX - MG - WRDC985
Iraan TX - MG - WRDQ495
Fort Stockton TX - MG - WRDQ495
Aspermont TX - MG - WRDF222
Bracketville TX - MG - WRDC985
San Angelo TX - MG - WQHF702
Talpa TX - MG - WRDM889
San Angelo TX - MG - WRDM891
Christoval TX - MG - WRDM891
McCamey TX - MG - WRDQ495
Hedley TX - YO - WPLX401
Dilley TX - YJ - WPJX747
Asherton TX - YJ - WPIQ557
Eagle Pass TX (8253 US Hwy 57) - YO - WPCN216
Talpa TX (1639 FM 2805) - YO - WPCB271
San Angelo TX (2964 S US67) - YO - WPCM985
Clarendon TX - YO - WPUF362
Cisco TX (8295 Hwy 6) - YO - WQBP321
Albany TX - YO - WPCB234
Welch WV - YO - WPCQ252 - LIKELY ONLINE
Bearwallow WV - YO - WPCQ252
Pineville WV - YO - WPCQ252 - LIKELY ONLINE
Elkhurst WV - YO - WPCQ252 - LIKELY ONLINE
Penhook VA - YO - WPCQ258
Stewartsville VA - YO - WPCQ258
Lovingston VA - YO - WPCQ258
Fancy Gap VA - YO - WPCQ258
Boonesboro VA - YO - WPWY757
Ferrum VA - YO - WPWY757
Duo WV - YO - WQBV595 - ONLINE
Panther WV - YO - WQCG997
Keen Mountain VA - YO - WQCG997
Pulaski VA - YO - WQCW816
Claudeville VA - YO - WQGY757
Institute WV - YO - WPCQ257 - ONLINE
Cameron WV - YO - WPCQ244 - ONLINE
West Liberty WV - YO - WPCQ244 - ONLINE
Bethlehem WV - YO - WPCQ244 - ONLINE
Wytheville VA - YO - WQIX253
Hurricane WV - YO - WPCQ251 - ONLINE
Point Pleasant WV - YO - WPCQ251 - ONLINE
Kiahsville WV - YO - WPCQ251
Lavalette WV - YO - WPCQ251 - LIKELY ONLINE
Alderson WV - YO - WPCQ253
Elgood WV - YO - WPCQ253
Ansted WV - YO - WPCQ256 - LIKELY ONLINE
Pulaski VA - YO - WPCQ257
Salem VA - YO - WPCQ257 - ONLINE
Coal Fork WV - YO - WPCQ257 - ONLINE
Madison WV - YO - WPCQ256 - ONLINE
Logan WV - YO - WPCT718 - LIKELY ONLINE
Harts WV - YO - WPCT718
Gilbert WV - YO - WPCT718
Tulsa OK - YJ - WRDK990
Honaker VA - YO - WPCQ254
Hansonville VA - YO - WPCQ254
Marton VA - YO - WPCQ254
Clintwood VA - YO - WPCQ254
Kenna WV - YO - WPSL862 - ONLINE
Sissonville WV - YO - WPSL862 - ONLINE
Flat Top WV - YO - WPCQ253
Rainelle WV - YO - WPCQ253
Huntington WV - YO - WPCQ251 - LIKELY ONLINE
Covesville VA - YO - WQGZ796
Benton Harbor MI - YO - WPCQ243 - ONLINE
Lawton MI - YO - WPCQ243 - ONLINE
Three Rivers MI - YO - WPCQ245 - ONLINE
Elkhart IN - YO - WPCQ245
New Carlisle IN - YO - WPCQ245 - ONLINE
Avilla IN - YO - WPCQ245 - ONLINE
Mishawaka IN - YO - WPPY425 - ONLINE
Rome City IN - YO - WPPY425 - ONLINE
Niles MI - YO - WQON223 - ONLINE
Butler IN - YO - WPCQ247
Fort Wayne IN - YO - WPCQ247 - ONLINE
Muncie IN - YO - WPCQ247 - ONLINE
Hartford City IN - YO - WPCQ247 - ONLINE
Lafontaine IN - YO - WPCQ247 - ONLINE
Winchester IN - YO - WPCQ247 - ONLINE
Fairmount IN - YO - WPCT717 - ONLINE
Decatur IN - YO - WPCT717 - ONLINE
Blufton IN - YO - WQHT567 - ONLINE
Bryant IN - YO - WQHT567 - ONLINE
Muncie IN - YO - WQHT567 - ONLINE
Middlebury IN - YO - WQIN299 - ONLINE
Dowagiac MI - YO - WQIN299 - ONLINE
Bangor MI - YO - WQIN299 - ONLINE
Covert Twp MI - YO - WQIN299 - ONLINE
New Buffalo MI - YO - WQIM299 - ONLINE
Buchanan MI - YO - WQIM299 - ONLINE
San Angelo TX - YO - WPCB226
Del Rio TX - YJ - WPCN220
Fort Stockton TX - YO - WPCB297
Rome City IN - YJ - WREJ482 - ONLINE
Fort Wayne IN - YJ - WREJ482 - ONLINE
Decatur IN - YJ - WREJ482 - ONLINE
Avilla IN - YJ - WREK675 - ONLINE
Three Rivers MI - YJ - WREK675 - ONLINE
Niles MI - YJ - WREK675 - ONLINE
Dowagiac MI - YJ - WREK675 - ONLINE
Ft Wayne IN - YJ - WREJ482 - ONLINE
Mooringsport LA - YJ - WREL564
Lawton OK - YO - WPCB298 - ONLINE
Fort Cobb OK - YO - WQBN220 - ONLINE
Rush Springs OK - YO - WQBN247 - ONLINE
Poteau OK - YO - WPCM980 - ONLINE
Pryor OK - YO - WPCB247 - ONLINE
Chickasha OK - YO - WPCB235 - ONLINE
Clinton OK - YO - WPCM973 - ONLINE
Weleetka OK - YO - WPCB295 - ONLINE
Okmulgee OK - YO - WPCB295 - ONLINE
Stigler OK - YO - ONLINE
Preston OK - YO - ONLINE
Henryetta OK - YO - ONLINE
Greenup KY - YO
Cisco TX - YO - WPCB238 - MG WRDK486 - WRDB601
El Campo TX - YJ - WREP260 - STX
Zapata TX - YJ - WPCB289 - STX
Experiment626
Logan WV appears to be online now.
Site 029-029
92715-1F7
00-0301 854.7625
00-0033 855.1625 CC
00-0373 855.6625
00-0505 857.3125
00-0543 857.7875
00-0623 858.7875
PEERS:
92715-1F7. 018-018 CC 00-0387, 855.8375.
92715-1F7. 040-040 CC 00-0253, 854.1625.
Please excuse any sloppiness in this post. I have never really used unitrunker to gather such data so I might have overlooked or included something that I did not need to.
mtindor
OH/WV DB Admin
Site 029-029
92715-1F7
00-0301 854.7625
00-0033 855.1625 CC
00-0373 855.6625
00-0505 857.3125
00-0543 857.7875
00-0623 858.7875
PEERS:
Excellent. Thank you. This has been added to the database.
18.18 is Kiahsville WV (Wayne) - WPCQ251 - still needs to be confirmed
40.40 is Madison WV - already confirmed and in DB
I am surprised it is not listing more peers. Or maybe it did list more peers but without a frequency (only an LCN) ? If so, please share those other peer site numbers and LCNs. But, it certainly ould be that Logan is currently only broadcastig those two peers.
We appreciate your efforts with yoru downstate sleuthing!
Mike
Experiment626
Mike
You're welcome. It is not listing any other peers at this time. I've been checking the 850MHz band for quite some time and so far this is the only AEP P25 site I've heard down this way. I'll keep my ears open and post whenever more pop up.
