Amp Charger vs G5 Internal and External Antennas
Uni1
Unication Representative
DFW Texas
I keep hearing that the Amp charger does or does not work with the internal and external antennas. The Amp charger works for both internal and external antennas. Here is a test on DMR, CSQ, P25 700, P25 800.
Uni1
DFW Texas
More
KevinC
Other
Super Moderator
Home
Thanks for the info. Previously we were told the secondary band was internal antenna only.
Was their a design change or has it always been this way?
Uni1
DFW Texas
Correct. External antenna on G4 / G5 is for 7-800.
APX8000
Sarcastic Member
AES-256 secured
How are you getting that DMR protocol ? I don’t see that option in the newest firmware.
Uni1
DFW Texas
We haven't released DMR yet. It will be unlocked on the next update.
I suggest using the diagnostics menu in the pager for RSSI. That is an engineering menu for testing.
KevinC
Other
Super Moderator
Home
Unfortunately it doesn't update frequently enough to be of any use.
Mine updates every second or so. What I don't like is it stops at -100 and won't show any signal stronger than that.
Whelen
Add external Antenna to Standard Charger?
Has anyone added a BNC or SMA jack to their standard charger? I have started this project and was reaching out to see if anyone had done the same. Thanks in advance for any input.
mattmac553
So when the G5 is in the amp charger both antennas switch over to the amp's antenna?
When I connect an antenna that is up a tower in the rear of my house with a BNC connection to the rear of the amp it would operate off that?
