Amp output
repeaterboy
Hello and thanks to the operators that have helped me out in previous posts.The info has been put to good use.I have another question.Im a bit confused as to why on 1 spectra i have,gives a reading of 26 amps on transmit and on another spectra i have does 29 amps.Supposed to be 31 amps on the spectra isnt it? I run them on a 40 amp power supply with amp readout. Thanks again for your advice operators.
fineshot1
NJ USA (Republic of NJ)
They were probably aligned slightly differently due to each radios individual characteristics.
Even if you have two identical radios it does not mean they will have identical characteristics.
Have you bothered to measure the rf power output of each radio?
I'll bet they are slightly different from each other which would account for the difference
you see in the current draw on the power supply.
