amp
cbrrider06
Hey folks kinda of a dumb question??? I just bought a amplifer on of flea-bay and I have no clue as to what freq. it will operate on. Is there any way of looking at the internal components to figure this out?????
k9rzz
Milwaukee, WI
The auction didn't say?
You gotta give us more than that if you want help. Homebrew? Tube or solid state? Commercial? What manufacturer? Does it go in a car, sit on a table, or do you need to knock out a wall to get it in the basement?
N1BHH
Jackson Square, East Weymouth, MA.
The question I have for you is why did you buy something you know nothing about in the first place? You could very easily be stuck with a brick. Always look it over before buying. Now I think this is a dumb question.
gewecke
Banned
Illinois
Is it of cathode tube vintage or is it solid state? If it's a tube design then what are the numbers/letters on the tubes? Maybe describe the controls on the front panel? There are many ways to determine what you have!
N9ZAS
cbrrider06
It is a mobile amp, no other manufactuer labels, the buttons on the front are power, low med hi, pre-amp. The auction did not say but for a 27.00 dollar gamble I will take it.
gewecke
Banned
Illinois
Maybe take the cover off and tell us what numbers are on the output transistors? That would give us some idea what band it's in.
N9ZAS
N4DES
Retired 0598 Czar ÆS Ø
South FL
If there are tags on the unit you can go on the FCC website and look up the type acceptance number.
kb2vxa
Banned
Point Pleasant Beach, N.J.
Rest assured it's a "2 pill" chicken band amp, solid state ham amps use MOSFET modules and their appearance makes them pretty obvious. If it hasn't any tuned circuits but rather as my guess input and output toroids likely it's a push-pull wide band amp that if you're lucky covers basically 3-30MHz it MAY be used to boost the power of a QRP rig or transceiver lowered to 5W, any more will blow it to kingdom come. Mind your harmonics and spurs, those things tend to be dirty so IMO I really wouldn't use such a thing. Another thought and another educated guess, if you lower the rig's output to 5W and use the amp likely it'll bring you back to the 100W the rig is capable of in the first place. <lulz>
"You could very easily be stuck with a brick."
How unkind but at least you tell it like it is, we call mobile amps (VHF in particular) bricks. <more lulz>
K
kb0nly
Guest
Sounds like another illegal CB amp, brought to you by the pit we know as FleaBay...
