Amplified charger Q
Holshot14
SC Penna
I have a G5 amplified charger, and I was wondering if there is a way to make the lowest volume, lower? I know it's to be amplified, but I mainly bought it for drop in charging, and for at night time. Well the wife is not happy with the lowest volume, lol.
Thanks.
Steve2003
Colorado
Thanks.
I noticed this with mine as well. Even with the volume all the way down on the amplified charger audio still manages to come through. I work from home and have the G4 on 24x7, whenever I need to take a call or jump on a meeting the only way to turn it down all the way is to either turn off the G4, or take it out of the charger and turn the volume all the way down.
Related to the amplified charger, I also notice that it seems to cut-off the beginning of most conversations (about 1/2 a second). And I know it's nothing to do with reception or anything of that nature. I had a few custom channel announcements that had voice at the very beginning of the recordings. The beginning of the announcement was always getting cut-off when in the charger and played fine when out of it. As an interim solution I ended up padding them with 1 sec of silence at the beginning so it's no longer noticeable.
I'm thinking I might be able to make a custom alert recording with a second or so of silence at the beginning and turn on voice buffering so the alert activates the speaker on the amplified charger... before it has a chance to cut-off the voice.
krokus
Southeastern Michigan
Thanks.
Plug in an external speaker, and pad that audio.
Sent via Tapatalk
