Amplifier
Aaron88
Ohio
How long does your coax have to be before you start experiencing signal loss? Thanks Hoser
HOLEBILLY
I put a amp on my 2096 and it works great. I pull in alot that I could nenver here before. Some channles on vhf did get overloaded but I just put on the att for the ones that was overloaded and they came in great. By the way I live in the sticks.
Aaron88
Ohio
My osp area is district 9 and I live in Wheelersburg and the patrol post is in Lucasville and should I still be able to monitor MARCS in my area?
Aaron88
Ohio
hoser147 said:
Depends on the coax itself the shorter the run the better. What antenna are you using on it now?
I am using a Radio Shack discone. I am also using low loss quad shield rg6 75ohm coax.
hoser147
Grand Lake St. Marys Ohio
How long of a run do you have? What are you wanting to monitor besides MARCs? Ive got both RS discones and really dont think that much of them on 800mhz. Right now Ive got a Scantenna up there and in my opinon it blows both of my discones away.
Aaron88
Ohio
50 ft. run and should I try scantenna? I usually monitor Scioto County fire departments (mostley Porter Township), New Boston and Portsmouth Police and Scioto County Sheriff. I want to try Marcs now though.
Aaron88
Ohio
My discone will reach Ashland Ky fire dispatch clearly from Wheelersburg with my discone and the freq. is 154.250
hoser147
I like my discones for that range of freq also, just dont seem to get it on 800. Have you tried using the 800 rs ducky? Or you may want to go with a better coax and see if that helps.
Aaron88
Ohio
I am thinking of replacing my discone with a Scantenna and what are the pros and cons of Scantenna?
