Amps hooking to mfj993b antenna tuner
Tintotty
does anybody know how to hook up a mfj- 993b automatic antenna tuner to a 300 linear amp?
alcahuete
Southern California
Not sure what you mean by hook up.
Radio is connected to input on the amp. Output on the amp goes to the Transmitter port on the MFJ-993b. Antenna port on tuner goes to your antenna.
prcguy
The tuner has various interface cables for Yaesu, Icom, Alinco, Kenwood and other popular amateur radios. With the interface cable it should tune the antenna when you push the tune button on the radio. For other radios I think it can be set up to tune automatically when the match is above a certain point but you would not want to tune with the amp on, tune at lower power then turn the amp on after its done tuning.
merlin
DN32su
You will want the installation guide. that explains the connections for tuning.
Basically the tuner uses low power (a few watts) tunes quickly then you can switch in any amplification.
Uses the 'tune' button on most radios set up for 'AT'.
