Amr Ltr
abqscan
DataBase Administrator
Moderator
AOA
[FONT=&quot]Is the 900Mhz AMR LTR system in the Metro area or is it out of Colorado Springs? I can hear in in Parker, but its very WEAK!
[/FONT]
captaincraig44
Arvada
Which system are you refering to? I'd be willing to plug it in and see if I can ID streets from the COS area if I can hear it.
abqscan
Moderator
AOA
This is what I have for the System....
Ch 3 936.75
Ch 7 937.75
Ch 16 938.75
Ch 28 939.75
firescannerbob
Colorado
AMR in Colorado Springs dispatches for several different areas (Colorado Springs, Pueblo, Canon City, Missoula, etc), however, AMR Denver is dispatched from Denver. It's possible that you have freqs for the Colorado Springs system in your scanner.
TDHG4U61
Denver, Colorado
Ch 3 936.75
Ch 7 937.75
Ch 16 938.75
Ch 28 939.75
I tried programming the above for LTR and when entering 939.75 my 396t read ' out of range'. any suggestion. The others went in okay , cool, one tg is 0-07-001
ericcarlson
Houston, Texas
Valid LTR Standard systems can only have channels numbered 01 through 20. 28 is not valid. If you look at the system linked to in this thread you will see the system is listed as LTR Passport which is not trackable by any current scanner.
-Eric
scanlist
Scanning since the 70's to today.
Greeley, CO
"Houston we have a problem!" :p
The metro AMR system is LTR standard NOT passport. If it's listed as such it is incorrect.
I had it prog in the 296 not too long ago. Real exciting stuff. :roll:
Don't have the LCN info handy at the moment. However my PRO-97 shows 939.750 as LCN 15.
Phil.
