Now with reguard to systems.
Conventional
Really only two ways to operate.
Most simple(Simplex):
You transmit on one frequency and the other guy hears you on the same
frequency. Easy as that.
Little more complex(Duplex):
Using a Repeater, you transmit on one frequency, repeater hears it and re-transmits it on a different. you receive on a different frequency than transmit.
Trunked
Hundreds of ways.
Main parts of the system. Controller and a bunch of repeaters.
Your transmit on a frequency that the controller decides on, which inturn opens a repeater for that frequency and allows it to work like Duplex above. Your radio and all others on the system are listening to the Control Channel which is what the controller is sending out telling which radios to transmit on what frequency and what talkgroup.
Keep in mind this is really really really basic. It is actually much more complecated then I have made it sound. It get's even more when you start talking about Statewide systems and such.
Now, don't think that for a system to be Trunked it has to be on 800mhz. You can operate any modulation on any frequency and convetional on any frequency. Trunked systems, for now, are only VHF(100-200mhz range) UHF(200-900Mhz range.)
If you have any further questions, please go a head and write, I'll try and help to the best of my ability.
Kevin
