Analog vs. digital battery consumption
NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
Hammond, IN
Just sitting here wondering if a scanner draws more power from the batteries when it is receiving a digital signal versus when it is receiving analog signals.
I'm wondering this because I've been at my desk for a few hours, listening to my PSR-800. The one scanlist I was listening to for a couple of hours was made up of all analog frequencies. The battery meter didn't seem to diminish all that much, but then I switched over to the Starcom21 scanlist, and it seems that the battery meter is diminishing much more quickly. In an hour it's gone from probably 75% to somewhere (i'd guess) around 25%.
K9WG
Greenfield, Indiana USA
In theory digital would consume more energy due to the processors having to work decoding the digital signal. How much depends on the way the decoding hardware was designed.
Georgia
That's what I kind of figured. Thanks for the confirming information. I appreciate it.
I have a PRO-106 Digital Handheld and before my county switched to digital, the batteries would last between 7-9 hours receiving analog only while scanning 4 banks of 20-30 channels each with a rate of 75% listening to active audio and 25% scan.
When my county switched to digital, reprogrammed the scanner for the new system and while scanning only the new system which consists of 1 control channel and about 8 talkgroups (that's all I have programmed anyway, there are many more on the system), my batteries only last between 4-5 hours and that is with a 50/50 split of listening to audio and scanning.
I was a little amazing that the battery would be used that much more quickly. I have a stock pile of Alkaline since I never have good luck with rechargables. When I am at home, it is always plugged in.
So I have to agree with the other posters, yes, digital does use more battery. I think it may have to do with the scanner constantly processing the control channel information let alone processing the signal when there is traffic to decode.
