Analyze Lcn finder again
kevtheskin
Hello all,
Another question on Lcn dmr finder. How do you use it. I have tried loads of times now and it finds nothing even on busy frequencies. It just sits there doing nothing even when signal bars are full. Are you meant to hear voice in this mode. Cheers for any info. Kev
bravo14
Polk County FL
Hello all,
What radio are you using? And what system like DMR or a trunk system?
kevtheskin
Hello again. Good video thanks tried what you said and nothing. I ran dmr decoder on my sdrplay and it finds lcn 4 to 3? . Where as the 3600 finds nothing ? Kev
Sent from my HTC One using Tapatalk
bravo14
Polk County FL
Does it show a rest channel?
kevtheskin
I think so. Will need to check later ?
Ubbe
Stockholm, Sweden
Dsd and dmrdecode are only decoding the restchannels information about what LCNs carry traffic. Uniden needs to have the correct frequency programmed for the LCN that carries traffic to be able to set the LCN for it. If LCN finder does nothing you probably do not have all the neccesary frequencies entered into the site.
/Ubbe
kevtheskin
If it does show the rest channel. You can put 1 freq for example say 1/2 is 451.xxxx put that as lcn 1. 3/4 452.xxx put lcn 2.
Hi here is what dmrdecode says.
DMR Decoder (Build 74)
11:14:56 DMR Voice Frame with Embedded Signalling
CACH : TACT Ch 1 Continuation fragment of LC
EMB : Colour Code 2 : First fragment of LC
11:14:56 DMR Data Frame (BS)
CACH : TACT AT=1 Ch 2 Continuation fragment of LC
Slot Type : Colour Code 2 CSBK
Capacity Plus CSBK : CSBKO=62
Activity Update : LCN 2 is the rest channel (Group 242 on LCN 1)
11:14:56 DMR Embedded Frame - Error !
CACH : TACT Ch 1 Last fragment of LC
11:14:56 Short LC : Capacity Plus Act_Updt - Rest Channel is LCN 2
CACH : TACT AT=1 Ch 2 First fragment of LC
EMB : Colour Code 2 : Continuation fragment of LC
EMB : Colour Code 2 : Last fragment of LC
EMB : Colour Code 2 : Single fragment LC
11:14:56 Embedded Single Block LC : Null
11:14:56 DMR Voice Frame (BS)
Hope it makes sense.K
kevtheskin
/Ubbe
Hello Ubbe.
Ofcom Wtr site shows only 2 frequencies for this site which is in the system site info?
Kev
Ubbe
Stockholm, Sweden
Keep that log working and it should eventually say that the rest channels have moved to either LCN3 or LCN4. If not, then there is only one frequency in that site, the one you are monitoring and set that to LCN1. If there are several sites in this system the dmrdecode will eventually (1-2 minute intervals) show that this is site 1 of 2 or something similar.
If the rest channel move, and you have no more burst of data on the frequency, you have to search higher frequencies to catch the LCN2 frequency, that would carry the same TGs as LCN1.
/Ubbe
kevtheskin
/Ubbe
Hello Ubbe, Is there any benefit using the Lcn if you already no the 2 shared frequencies? Im not really understanding this whole Lcn thing Lol.
bravo14
Polk County FL
I see its color code 2 and looks like 1 freq is being used. Try to put LCN 1 in the Freq edit section. The program should have showed what site it is. I don't see that.
kevtheskin
Hello again,
I will re-run dmrdecode again and save the log. What do you need me to look for? As to my question before do you need lcn for monitoring?
Kev
bravo14
Polk County FL
Hello again,
Kev
Yes you'll need to have lcn to follow talkgroups. You can try LCN 1 see what happens. Run the DSDPlus again for about 30 mints see what pops up.
Ubbe
Stockholm, Sweden
The system sends out data on the control/rest channel and when a conversation starts it will send out what LCN that conversation are using. The "real" radios in the system are programmed so say what frequency each LCN are using. With a scanner you do not have that info and you must figure it out for yourself. Unidens LCN finder could help but it is easier using DSD+ and Dmrdecode.
If the freqeuency and LCN do not match exactly the scanner will try and monitor a frequency where there is no conversation and goes back to the control/rest channel and repeat until it uses a LCN that has a correct frequency.
/Ubbe
kevtheskin
/Ubbe
Me again. Tried using Lcn1 and nothing happened?
Here is the dmrdecode log from 453.750
You have selected not to display CACH data
You have selected only to display frames without errors
19:57:13 DMR Data Frame (BS)
Activity Update : LCN 2 is the Rest Channel
19:57:17 DMR Data Frame (BS)
19:57:22 DMR Data Frame (BS)
19:57:38 DMR Data Frame (BS)
Activity Update : LCN 4 is the rest channel (Activity on LCN 3)
19:57:38 Short LC : Capacity Plus Act_Updt - Rest Channel is LCN 4
Activity Update : LCN 1 is the rest channel (Activity on LCN 3,Activity on LCN 4)
Other frequency is 453.925
19:55:15 DMR Data Frame (BS)
Slot Type : Colour Code 2 Terminator with LC
Group Voice Channel User LC
Service Options : Non-emergency/No priority
Group Address : 243 Source Address : 1416
Activity Update : LCN 1 is the rest channel (Activity on LCN 4)
19:55:15 Short LC : Capacity Plus Act_Updt - Rest Channel is LCN 1
Makes know sense to me :(
Ubbe
Stockholm, Sweden
Looks as if both frequencies are LCN1/2 and must be two different sites. The frequencies are probably too close to belong to the same site. You don't have any more DMR channels a bit higher up in frequency?
Enter these two frequencies in two different sites as LCN1. When you find two other frequencies with CAP+ signalling you program one in one site and the other in the other site as LCN2s. If that doesn't work you have to switch the LCN2 frequencies around.
/Ubbe
kevtheskin
Hello again. The frequencies are pared on the UK Ofcom licensing site under same owner ?
