Anderson / Madison Co. Fire Tone-Outs
afdscan
Central Indiana
I recently downloaded the comtekk software and have found it to work very well. With the BCD396 / 996 units you don't have to be exact. I have entered the tones that I decoded and they work great. I thought I would share them with anyone interested.
Anderson Fire:
M-1, E-1, 20 (HQ): A-553.4 B-581.5
E-2, M-3: A-553.4 B-614.1
E-4 ?
E-6: A-553.4 B-764.7
E-7: A-553.4 B-807.6
E-8, M-2: A-553.4 B852.9
All Call: A-976.1 B-877.5
Pendleton: A-623.3 B-1155.4
Chesterfield: A-456.1 B-503.6
Lapel: A-410.3 B-1155.5
Ingalls: A-370.0 B-410.3
Richland Twp: A-688.8 B-561.4
Frankton: A-589.7 B-681.5
Summitville: A-764.7 B-410.3
I'm still working on Adams Twp, Edgewood, Elwood & Alexandria.
WA9JGB
Central Indiana
Can you use your software and do the same for Johnson County? There County Fire is 154.010. I have been trying to get the tones for about 3 months now. What did you use?
WA9JGB
Central Indiana
Software
I just downloaded the software. The screen goes crazy, but after the transmission is over there is the 2 tones. tone A and tone B. It's seems as if it goes through a ton of tones but the end result ends up on the screen. Pretty cool. Well worth the money. I will have Johnson County tones decoded hopefully in a week or so. Thanks for the post. There are so many software packages out there. Nice to hear some positive feedback from one.
fireman55
I thought AFD had a diffrent tone for each truck, or is it per station? Monitor Madison County Dispatch between 4 and 6 pm they usually have a test every night. I think Duck creek and Pipe Creek have a test at 5:30 pm everynight too.
afdscan
Central Indiana
It appears the tones are per station (at least that is what the decoder is showing). I can't get a good signal from Elwood. I have some local RF issues.
WA9JGB
Central Indiana
Well It's working so well today. I tried to calibrate it and I get the message.
No Cal Tone. It won't calibrate. It says in the manual to use a 1/8 inch stereo cable, and I think I am using a mono cable. Maybe that's the problem.
afdscan
Central Indiana
That could be the problem. You also may want to check your sound card. Make sure the proper inlet is activated too.
WA9JGB
Central Indiana
I fixed it. Everything is working great now. I'm just waiting for the county to send out some tones.
