Announce & Roger tones HT/CDM
SpringHill
Spring Hill. TN
As the title says I’m curious on how you’d go about activating or programming announce and roger tones on an HT1250/CDM1550.
Thanks for your help!
62Truck
Ordinary Subscriber
Uranus
What are announce, and roger tones? I've been around, and programming these radios for a while, and I've never seen announce, and roger tones.
SpringHill
Spring Hill. TN
Maybe I called them by a wrong name but basically the noise that lets you and other users know when a radio keyed up and ended transmission
N4KVE
PALM BEACH, FLORIDA
These tones became popular with CB back in the "trucker" days. Then when the $10 bubble pack GMRS radios came out, they did the same thing. Professional [business] radios have no need for "ROGER" tones. However, some trunking, or DMR radios do generate a tone to tell the user it has acquired the repeater, & the transmission went through successfully.
K4RMN
I know with the XTS5000s you can put a single-tone beep on the radio when you key up and another when a received transmission ends, but both of these only apply when the transmission being sent or received is non-secure. I have the transmit tone on mine as a makeshift PTT beep to let me know when I've keyed up in a noisy environment such as on the roadside or the fireground. (I passed on the receive beep, got annoying fast.)
N1SQB
Somewhere On Earth
Transmitting MODAT on an amateur repeater is the quickest way to make enemies, or get thrown off that repeater. It's just not COOL.
I didn't say where or when it should be used if at all, I'm just trying to identify what the OP is most likely referring to.
Manny
SpringHill
Spring Hill. TN
I guess at the end of the day I’m looking for this minus the repeater at this point. Is that even possible?
