I don't know if this is something that can be fixed in firmware or not but on my several BCT15's "Permanent" lockouts are not retained unless the radio is shut off while power is still present. If you pull power (such as by ignition switch or from the power supply) the permanent lockouts are not retained.
If you do a lot of limit or service searches and lockout a whole bunch of channels be sure to turn the radio off before removing power, otherwise you have to lockout all those channels again.
It appears they fixed this in the BCT15X and BCD996XT. I assume the issue is also present in the 996T but I no longer have any of those to try it on.
