Another bleed over issue
nick1427d
IL
I have a BC780
Monitoring two FD dispatches
1) 154.325
2) 154.310
both are CSQ on dispatch but I get bleed over on 154.325 from the 154.310. I'm close enough to both that I hear both crystal. I know a beam would help but would like to not go that route. I programmed both at times as FM and NFM but no fix.
Any thoughts
timkilbride
Linn Co Iowa
I have a BC780
1) 154.325
2) 154.310
Any thoughts
Have you tried the attenuator?
Tim
gewecke
Banned
Illinois
My suggestion too. It's helped my 780 ;)
73,
n9zas
nanZor
You may want to research this here on RR about Uniden vs RS scanners and the narrow fm filters. I know I've seen it a year or two ago. You may want to look into a high-end rs scanner if these two closely spaced users are super important.
This might be the case that the Uniden does not actually have a true narrowband fm filter bandwidth - just audio compensation. On the other hand, modern high-end radio shack scanners actually switch to a much narrower rf filter bandwidth, but don't compensate for the audio properly. One user said that the RS scanner, while not perfect, allowed for the truly narrowband filtering from an rf standpoint at least.
gewecke
Banned
Illinois
Nick,
Another trick which may help, besides selective use of the attenuator would be to program all your vhf frequencies in NFM instead of FM. ;)
73,
n9zas
nick1427d
IL
Here's what I've done so far that "helped" my issue but I'll leave it alone and deal with it
1) Attenuator made the 154.325 scratchy, attenuation on 154.310 isn't going to help my bleed over onto 154.325 so I forgot that option.
2) Since both are fairly strong and only for dispatching I programmed the 154.325 into 154.3255 and it helped with bleed over and still allowed me to pick it up.
Sometimes I go straight here with my questions cause I know they'll be answered!
Thanks for the help
gewecke
Banned
Illinois
Thanks for the help
Try prog those frequencies in NFM rather than FM. :wink:
73,
n9zas
nanZor
Uniden's NFM as I understand it uses the same if filter as FM - it is just an automatic audio compensation for the narrow deviation if you use NFM, although the deemphasis is correct. RS on the other hand has separate IF filters, but only boosts the audio in overall amplitude without the deemphasis. At least, that was what I read from the earlier reports.
