I raved about the SDS100 last month immediately after getting my hands on it simply because it passed my one test. I live within 7.5 miles of two towers that transmit the Louisville Metrosafe system. With my 436HP, it wasn't worth listening to. The SDS100 fixed that problem. Before diving deeper into my dilemma, let me preface it by saying that I spent very little time until now testing other systems (mistake) and 100% assumed that the 436 and SDS would be nearly equivalent except for improved simulcast reception. By other systems, I mean Indiana Safe-T and others on my side of the river. I live in Indiana, but I'm right on the river. I have the greatest interest in the Indiana systems, but it can be boring while Louisville is almost always entertaining. Unfortunately, at my house, I have discovered that the SDS is missing at least 30-50% (conservative guess) of the transmissions that the 436 is picking up on the Indiana Safe-T. I loaded the exact same profiles into each and also used the exact same antenna (RS 800 MHz). I even swapped the antennas to be sure that one of them wasn't faulty. All service types are on. Here's the interesting part; the talk groups that my 436 receives at home that the SDS does not, will come in crystal clear 8-10 miles down the road (closer to the more populated areas of New Albany, IN and Louisville, KY). The transmissions that the 436 picks up at my house that the SDS does not are almost always crystal clear and always have been. Literally, for the last 10 minutes the 436 has been constantly receiving transmissions on Clark County Safe-T talkgroups while my SDS is quite. With the SDS, I can now listen to Louisville, but if I want to listen to Indiana Safe-T, I have to use the 436. How can this be? I've had my 436 for years and the radios are so similar that I don't think it's incompetence, or a basic setting. I'm thrilled that I can finally listen to Louisville from my house, but not if I have to sacrifice a large percentage of Indiana Safe-T. It's too late to return it. I've read through almost all of the posts regarding "missing transmissions" and haven't found a fix. I guess I'll have to send it in and have it tested. If it tests ok, then I made a huge mistake. Any suggestions or ideas would be greatly appreciated. To be clear, I know the SDS will receive the talkgroups that I miss at my house because it will pick them up when I change locations, but I refuse to believe that Uniden put a radio on the market that is inferior to it's predecessor (except for simulcast). Not sure what to do at this point.
