Another dumb question . . .
mule1075
Washington Pennsylvania
Would an external antenna -- discone, Scan King, etc. -- tend to overload a handheld scanner (BC125AT, SDS100, etc.)?
Depends on a lot of variables. Location of near by high power radio transmitters etc. If you are asking if a difference between a handheld or base/mobile unit I have not seen a difference.
KB2GOM
Rensselaer County New York
So basically, the circuitry of handheld in terms of electrical performance is the same as its base/mobile twin . . . for example the SDS100 and SDS200 or 536/436?
That's good to know. When I wrote for Passport to World Band Radio, there were some portables that were tuned "hot" to maximize the performance of their attached whip antennas and hooking up, say, a long wire could easily result in overloading.
Thanks for the reply.
MDScanFan
USA
For what it’s worth my handheld scanners, including the 125AT, exhibit lots of intermodulation products when connected to a wideband outdoor antenna like a discone. The only way I can mitigate it is to add notch filters at the antenna input. For instance, one for the 152 MHz and another for 162 MHz when I try to listen to the marine band. My base scanners tend to exhibit the same issue.
WB9YBM
It's more a function of how strong a signal is when it arrives in your receiver; the external antenna would be a help for distant or low-power stations, but if you've got close-in or high-power stations nearby, yeah, there's a risk for over-load as well as adjacent frequency "splatter". I had that happen with an older ham radio hand-held when I hooked it to a base station antenna (an omni-directional at 50')--at least that old model radio I was using just wasn't intended (and therefore not designed for) long-haul work (although technological advancements made since then may have improved the situation somewhat).
