Could losing the control channel be a symptom of a multi site simulcast system........ Saginaw county Michigan....... thank you in advance
I live in the same state as cg (Not nearby) and own the 325P2.Just because a system is simulcast doesn't automatically mean that you will have issues. I have a several simulcast systems I can pickup.
While others continually push the false narrative that simulcast distortion is not an actual issue for many people in many locations (especially when mobile), and continue to insist that just because their scanner works fine in their situation, so should everyone else's and that specifically engineered hardware is a waste of money.I don't have any issues at all with simulcast. Some people just like to push the more expensive scanners.
Them folks don't realize how lucky they are by not having simulcast decode issues. Just because some folks hit the Powerball doesn't mean everyone will hit the Powerball.While others continually push the false narrative that simulcast distortion is not an actual issue for many people in many locations (especially when mobile), and continue to insist that just because their scanner works fine in their situation, so should everyone else's and that specifically engineered hardware is a waste of money.![]()
I disagree, respectfully. If you have simulcast issues, you will not lose the control channel, rather, just like all the voice channels, you are getting too much from too many sites.Losing the control channel is a classic sign of simulcast issues.
