Another newb question
ch40n1k
Lakewood, Colorado
So I can log the heck out of the horsetooth and bald sites with Pro96Com. See all kinds of affiliations and radio information.
I have a 100% receive rate. But when I try to listen to ft. collins etc, I get nuffin'. Anyone have any ideas as to why?
abqscan
DataBase Administrator
Moderator
AOA
I don't think we have enough data to help you... What radio are you using, what TG's are you trying to monitor...
ch40n1k
Lakewood, Colorado
Sorry about that. I'm using a PSR-500. The talkgroups that I'm trying to monitor are Larimer County SO, Ft. Collins PD, Weld County SO and EMS etc. (4029, 4031, 2455, 4045, 4036, 4069)
Here is some of the logged data:
System ID : D1C
System Name :
WACN : BEE07
Tower Number (Decimal): 362
Tower Number (Hex) : T033E
Tower Description : (null)
Control Capabilities : Data,Voice,Registration
Call Sign(s) : Unknown
Timestamp : Sun Apr 06 13:25:19 2008
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625
01,762.00625,0.00625,30.00000,"Confirmed",0.00625
-Frequencies
#Format: Channel,Usage,Frequency,Input Frequency
"00-0267","v",852.67500,807.67500
"00-0285","v",852.78750,807.78750
"00-0327","v",853.05000,808.05000
"00-0339","a",853.12500,808.12500
"00-0377","a",853.36250,808.36250
"00-0433","a",853.71250,808.71250
"00-0461","c",853.88750,808.88750
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
313,"T030D",d1c,"00-0361",853.26250,""
326,"T031A",d1c,"00-0369",853.31250,""
352,"T0334",d1c,"00-0451",853.82500,""
359,"T033B",d1c,"00-0203",852.27500,""
360,"T033C",d1c,"00-0437",853.73750,""
361,"T033D",d1c,"00-0421",853.63750,""
363,"T033F",d1c,"00-0441",853.76250,""
Talkgroups:
"04/06 13:22:10","Unaffiliate","","305371",""
"04/06 13:22:15","Affiliate"," 4029","305371","TG: 4029 DT: 4/6/08@13:22"
"04/06 13:22:15","Affiliate"," 2451","337582","TG: 2451 DT: 4/6/08@13:22"
"04/06 13:22:21","Affiliate"," 4029","305603","TG: 4029 DT: 4/6/08@13:22"
"04/06 13:22:25","Affiliate"," 1913","327452","TG: 1913 DT: 4/6/08@13:22"
"04/06 13:22:28","Affiliate"," 4031","305603","TG: 4029 DT: 4/6/08@13:22"
"04/06 13:22:28","Affiliate"," 4029","305527","TG: 4029 DT: 4/6/08@13:22"
"04/06 13:22:38","Affiliate"," 4031","305389","TG: 4031 DT: 4/6/08@13:22"
"04/06 13:22:44","Unaffiliate","","305371","TG: 4029 DT: 4/6/08@13:22"
"04/06 13:22:49","Affiliate"," 4029","305371","TG: 4029 DT: 4/6/08@13:22"
"04/06 13:22:49","Unaffiliate","","305371","TG: 4029 DT: 4/6/08@13:22"
"04/06 13:22:53","Affiliate"," 2455","337516","TG: 2457 DT: 4/6/08@13:22"
"04/06 13:23:04","Affiliate"," 4030","305678","TG: 4030 DT: 4/6/08@13:23"
"04/06 13:23:13","Affiliate"," 4029","305389","TG: 4031 DT: 4/6/08@13:22"
"04/06 13:23:24","Affiliate"," 4029","305394","TG: 4029 DT: 4/6/08@13:23"
"04/06 13:23:25","Unaffiliate","","305527","TG: 4029 DT: 4/6/08@13:22"
"04/06 13:23:25","Affiliate"," 1946","327902","TG: 1946 DT: 4/6/08@13:23"
"04/06 13:23:42","Affiliate"," 9150","309149","TG: 9150 DT: 4/6/08@13:23"
"04/06 13:24:20","Affiliate"," 4029","305603","TG: 4029 DT: 4/6/08@13:22"
"04/06 13:24:21","Affiliate"," 4029","305673","TG: 4029 DT: 4/6/08@13:24"
"04/06 13:24:23","Affiliate"," 4036","306974","TG: 4036 DT: 4/6/08@13:24"
"04/06 13:24:26","Affiliate"," 4045","306458","TG: 4045 DT: 4/6/08@13:24"
"04/06 13:24:35","Affiliate"," 4045","306451","TG: 4045 DT: 4/6/08@13:24"
"04/06 13:24:44","Unaffiliate","","305518",""
"04/06 13:24:48","Affiliate"," 2455","337501","TG: 2455 DT: 4/6/08@13:24"
"04/06 13:24:49","Affiliate"," 4029","305402","TG: 4029 DT: 4/6/08@13:24"
"04/06 13:24:50","Affiliate"," 1913","327466","TG: 1913 DT: 4/6/08@13:24"
"04/06 13:24:54","Affiliate"," 4069","307052","TG: 4069 DT: 4/6/08@13:24"
scanlist
Scanning since the 70's to today.
Greeley, CO
Some days things are very active other days it's very quiet.
Larimer SO makes the switch on Wed 4/9 according to the press. Only TAC-3 has been active lately.
FCPD is intermittent on the Bald site and is kind of quiet during the day since they use MDC's.
Weld SO same thing. Weld Fire and EMS groups are normally quiet.
Phil.
firescannerbob
OG Feed provider
Colorado
Also...an "affiliation" doesn't always mean that radio is generating any radio traffic. It merely means that the radio is turned on, and it is set to a certain TG. A quiet radio will generate an "affiliation".
ch40n1k
Lakewood, Colorado
Phil.
Thanks for the info. I had half expected that they would be fairly quiet ... I just wanted to confirm that I could actually hear them all the way down here.
ch40n1k
Lakewood, Colorado
I also did not know that. Thanks. I wasn't sure whether the radio had to be in use to affiliate.
Thanks again guys!
Paul
