Nothing new here other than a place to post my findings using different 1/4 wave coaxial open cable stubs. I have problems with 152 MHz, which is often used as a pager frequency and is actually stronger than any of my nearby FM radio stations. I also have a strong signal from NOAA WX on 162.400 MHz. Thus, the point of this thread is the results of using different coaxial stubs to clobber 152 & 162.xx MHz. As a stub filter is typically quite broad, just one will handle those two frequencies, and more. Of course "more" is probably frequencies you may not want it to work so well.
Before things get out of hand...this is about experimenting. I know a tuned notch filter, in particular one's made by Dale Par are available for each of my problem frequencies. I actually own the 152 amateur version which really does knock it down to almost 60 dBm. I own several other of his various filters as well. I also understand about harmonics, which in my case the stub helps with other problematic UHF frequencies too.
Anyways, I had some junky BNC RG58U patch cables in the bin. I figured I would see if I could repurpose them or back they would go in the bin; they worked. I also had some LMR 400 to test with. I have some LDF4-50A as well. I will cut a properly sized piece and post that result as well. The velocity factor is different for each coax, so slightly different lengths are needed. I used this website calculator to get my 1/4 wave length and added five cm or so, cutting it down to size while looking at the graph on a vector network analyzer (VNA). I was cutting about 1.5 cm each time and stopped when it was close enough.
Velocity
LMR 400 is 85 and the RG58U is 66.
On 152 MHz
- RG58U reduced the signal about 21 dBm
- LMR 400 reduced it about 40 dBm
ON 162.xx MHz
- RG58U reduced the signal about 23 dBm
- LMR 400 reduced it about 22 dBm
The LMR 400 provides a deeper notch and I use that with receivers that monitor the air band as well as others. The RG58U clobbers things well enough and I use it inline for a receiver for monitoring 225 - 400 MHz. Unfiltered, the 152 MHz signal provides me with RFI all the way up into the UHF third harmonic of 456 MHz and more. It is interesting to see on an SDR waterfall other signals and the noise floor shift when that 152 pager TX kicks in.
Velocity
On 152 MHz
ON 162.xx MHz
