Looking at a used mfj 269 on ebay
Wondering what the difference might be in this vs the 269c
I 100% agree. The FA-VA5 provides coverage to 600 MHz and has so many features built in. When used with a computer, it can provide a graph of any slice of spectrum within its 600 MHz range. The unit is completely self contained, including AA batteries which install inside. Using it with a computer will power the unit via the USB connection. It is a kit, a small amount of assembly is required but should be no issue for most. The unit comes with calibration loads which also require user assembly. I purchased the high precision loads which come fully assembled and pre-measured as to their inductive and capacitive values. These values can be entered in the menu of the analyzer for high accuracy.Take a gander at the FA-VA5 over at www.sdr-kits.net. It is way better than any MFJ product!
do you need an amateur license to use one of these?
The 600MHz upper limit is kind of a dealbreaker if you need to test at 900Mhz.
... When used with a computer, it can provide a graph of any slice of spectrum within its 600 MHz range. The unit is completely self contained, i...
I'm familiar with the term; the GPS modules I install in scanners happen to have the ability to output a disciplined oscillator frequency.The ability to attach a GPSDO (let me spell that out for you: Global Positioning Satellite Disciplined Oscillator) to it and have the confidence that your frequency accuracy approaches 1x10-12)!!... Let me say that if you have to ask... You'd better go help Grandma with the dishes...
Any idea where the program can be found ?
But we're talking about an antenna analyzer here
Yes, you are correct with that statement but the OP of this thread is only speaking of an MFJ product and the FA-VA5 will be a much, much better product than MFJ will ever produce...
So, to drag it out since it's your thing to do...
Now, in my opinion.. and suggestion to the commenter: JoshuaHufford (which should have been asked in his own thread) to reach 950MHz (1.3Ghz to be more precise) with confidence and product support that I don't see in many other products, comes from the guys that had a hand in the design of the FA-VA5 is the DG8SAQ VNWA 3 over at www.sdr-kits.net.
But wait, there's more....
Very well made and documented calibration kits to getter-done the proper way... (which you won't ever see from those Cheesiness analyzers)
And even more...
So sorry to disappoint you, but no, your Cheesiness analyzer doesn't even come close and is why it's only $69.95 with free shipping from China on Amazon... So if you are so hell bent in wasting your $69.95 on an inaccurate child's toy without support - but hey, it does include this cool plastic unshielded case for free!!, who am I to stop you...
Now, may normal scanning finally resume???
A broken watch is correct twice a day.My MFJ 259B has lasted for years...
The common similarity is they are both made by MFJ and they will fail prematurely. You might look at the Comet CAA-500 or even one of the cheap Chinese analyzers will work better and last longer.
I'm afraid you're mistaken. MFJ gear does very well in most cases. The cases where they fall short is usually because of the operator not knowing what the thing is capable of to start with, unrealistic expectations. Yes, I have had an MFJ device 'quit' before. After contacting MFJ I was told what the problem was and how to fix it, or, the option of sending it back. In my case, it was a simple part replacement (29 cent resistor). I figure that wasn't bad for a 6 - 8 year old thingy.
