ch1158
Hello, I was wondering if somebody could help me with some equipment recommendations. I am pretty new to this and looking to buy some solid equipment so I don’t have to upgrade in the future. I currently have a BCD436HP and am adding an SDS 100 soon as well as a scanner solely for VHF bands which I will gladly accept recommendations on.
I am looking for some advice on antennas and a splitter to go to these two scanners. These scanners will be monitoring my local P25 trunked systems but looking to scan as far as I can. As far as I have read, the Diamond Antenna D-130J seems like a good choice for a multidirectional antenna. Are there any others that are superior for monitoring LMR-400UF seems to be the best cable option as well but looking for recommendations on all of this. Planning on mounting the antenna on my roof and running the lines to my basement which will be around 75 feet. I am also wondering if that antenna will be good for the VHF scanner or if I should look into getting a separate one for that?
Since the LMR400 seems to be very heavy, any advice on what I should run from the cables after they split to the radios themselves? Something not as strong that is movable so my radios do not get damaged. I am looking to build a very small portable stand for the radios that I can move back and forth in my basement around 10 feet from my desk to the couch. On this stand, I was thinking of mounting the splitter on the back or should that be a further distance? Basically does there need to be LMR400 running after the splitter to the radios or can my homemade stand hold the splitter and run the less bulky wire to the radios? This may be confusing so I can clarify as much as need be.
For the separate radio solely monitoring VHF which one would you guys recommend and would I need a separate antenna for it that is more tuned for VHF waves? If so what cable would I need for it as I would rather not buy double the amount of LMR400 as it gets pricey but I am looking to make this a permanent setup and not have to make upgrades in the future so any recommendations will be great.
Any help would be greatly appreciated, thanks!
