Antenna Choice help
Tryton
Largo, Fl
Hi all, I just purchased the Larson 150/400/800 It works good on those freqs but I also want to listen to cb and aircraft bands, can anyone help with one? also has to be nmo mount.. thanks again
Tryton
Largo, Fl
how well is it with air freqs? I am really getting into aircraft monitoring
.. thx!
3mary2
Las Vegas, NV
I have the Larsen mounted on my truck and it does well with Nellis AB. CB is not my thing so to speak, but I can hear channel 19 when traveling.
Tryton
Largo, Fl
I'm using it for a base.. I'm on the 2nd floor indoors, My bedroom has vaulted ceilings so I put it up towards the center of my room as high as I could go. I pull in a few freq's I couldn't before on the 400 range and the 800 range has also improved.. When I try to listen to air band I can here but its very low, and staticy. when I tune to CB, I get barley anything, I hear what sounds like very soft voices but static when they are talking.. I just need an Antenna so I can pull in air and cb.. but If I had to make a choice between the two, I want air band the most.. Thanks for your recommendations!!!
Sinister
New Hampshire
Did you provide a ground plane? Metal ground plane is still required (8" diameter minimum)
Tryton
Largo, Fl
I am sorry? I don't know what you mean.. All I did was hook up the antenna and mount it up high in the wall and connect it to the back of my scanner via the connector.. I dont really know what a ground plane is.. Im very new to antennas sorry.. I just figured this would be better then the stock whip.. :confused:
Tryton
Largo, Fl
ok, how do I hook up a ground plane? It didnt come with the antenna? Where do I buy one? (Sorry in advance for the questions)
W6KRU
Vista, CA
Posted on the solid signal site for that specific antenna as the minumum size for ground plane
Hmm. I can't find anything on the solidsignal. com site for that antenna. After looking around for a while I searched the site for Larsen and it only found 4 antennas and they were all for cell phones. :confused:
ratboy
Toledo,Ohio
A friend of mine was living in a tiny apartment while his house was being repaired after the roof collapsed, and he used a couple of mag mount antennas with larger steel cookie sheets for groundplanes. They were pretty cheap and had a use when he didn't need them for use with his scanners anymore.
Hoofy
Laurium, michigan
If you have access to a HAM radio guy or an antenna analyzer you could try this.
I took an old set of rabbit ears and connected the coax center wire and the shield to the individual telescoping antenns and then with the analyzer I lengthened or shortened the antennas until I got what worked the best.
I mounted the rabbit ears in the attic to start with and went from there.
If you try this don't stand too close to the antenna while tuning as it will have an effect on the antenna and tuning.
Sinister
New Hampshire
My appologies Dan you are correct.
I just did a search again and I was too quick on grabing the info.
The spec given on the size was for Wilson Electronics 301104 which is a cellular antenna.
But yes you do still need a ground plane.
W6KRU
Vista, CA
My appologies Don you are correct.
OK. I'll buy that. 3.5" is a 1/4 wave at 800, so 8" sounds pretty close to 1/2 wave at 850 MHz.
