I need to run a few coax cables through the exterior wall of my home office. It's dry wall inside and brick outside. My concern is the insulation. I have that pink woolly stuff that likes to catch on a drill bit and spin it up into a ball inside the wall, destroying the insulation properties and sometimes makes it almost impossible to remove the drill bit. I learned this the hard was when I was running cable for security cameras.
What's the best way to overcome this? Do you just run the cable through the wall or do you use some type of bulkhead with coax connectors?
Thanks!
Thanks!
