Antenna Coax changes.
Allan_Love_Jr
Blair,Nebraska
Hi everyone.
The last time I chimed in I showed you all my new Antenna setup. I had the Scanner Coax running from the Antenna connector. Going through a "Loop". Then I routed it down in the Pipe. Not anymore. I went back up just today and changed everything around. This time I routed the Coax from the connector right down the outside of the pipe and down to my Scanner. What a Big improvement. I will upload some photos later. Later.
Allan_Love_Jr
Blair,Nebraska
Improvement in performance, looks, or both?
Can you give us some more details about this improvement?
I was loosing Signal when the coax was looped and running it in the pipe. Since the coax is now not looped and is running right down the side of the pipe. The signal strength is alot stronger.
