>I now have first-hand experience on 1:1 balun from LDG. That's not happening again. Also based on this new experience I shall not give any >benefit of the doubt to any discussion in the forums about baluns. The design Nooelec used works for reception!! The design LDG used >is for transmission!! The loss in the Nooelec balun 1:9 v2 is negligible at best!!
I'm surprised by this response. A transformer is used to transform the impedance of an antenna to the impedance of the radio.
Your radio is generally 50Ω and a dipole is is 72Ω at the frequency it is cut for (at a reasonable height). The 50Ω to 75Ω mismatch
creates a minor loss, I think it is 0.2db. Now if you tune different frequencies than your antenna is tuned (cut) to the impedance can swing considerably. I suppose at some frequencies you 9 to 1 would be correct but that would be very hit or miss.
As someone else said your noise problem is a different issue. It can be eliminated using feed line chokes, ground breakers, burying the feed line, I have went to using Cat5 cable to eliminate feed line ingress. and I'm very happy with it. It is 100Ω impedance, so does require different transformation.
Your spectrum is 27MHz but then you mention 13MHz, 6Mhz and 5MHz signals
Seems like there are many better choices for a wideband SW antenna than a dipole cut to 27Mhz.
A wide band antenna will have a more stable impedance over frequency.
If I need to be corrected, I'd be happy to learn. Thanks.
Mikek
