The SMA antenna connector on my BCD436HP is loose. It's moving from side to side slightly. Reception of strong signals is still good now, but I can tell that it's not as good on weaker signals. I assume this may get worse.
The connection is soldered to the board inside the scanner, correct? So this is probably not something I should attempt to fix? Just wondering if others have had experience with this, and what you did.
Thanks,
Dave
Thanks,
Dave
