I need a long antenna and I have a L mount.
How are you determining you need a "long" antenna? Is it aesthetics? Is it because that is what someone else is using? Is it because you think you need the additional gain?
Antennas are frequency dependent. You don't necessarily purchase them by the length, you purchase them depending on exactly what frequencies you'll be using.
As stated above, for the frequency range you are using, you'll need an antenna that is resonate on those specific frequencies.
You could choose a 1/4 wave antenna, which will be a few inches long and provide zero gain, but has a nice radiation pattern. You could choose a 5/8th's wave antenna that will be about 12 inches long, have about 3dB of gain and have a slightly more compact radiation pattern. You could chose a co-linear design that will be longer, have higher gain, but will have a very tight radiation pattern.
What you really need to do is take a close look at what your department is using on their apparatus. Radio systems, specifically repeaters, are designed to provide coverage over a given area based on a number of variables. Usually, the coverage is determined by placement of the repeater, antenna height and antenna gain. System coverage shouldn't really be determined by the end users antenna choice. Keep in mind that these repeater systems are usually designed to provide a certain level of coverage for a hand held radio running 4-5 watts with a very inefficient antenna. Likely, the fire apparatus has an antenna on the roof that has been deemed suitable for the radio system. Take a look at that type of antenna as your choice. If it works on the fire trucks, it should work well for you.
Also, going with a much higher gain antenna when it isn't necessary can actually cause some issues. With higher gain antennas, you could be putting out more power than necessary and could conceivably cause interference to co-channel users farther away.
Also, depending on your local terrain, higher gain antennas are not always the best choice. Sometimes lower gain antennas will outperform higher gain antennas.
In other words, don't just pick an antenna based on looks and gain figures.
