thedogfood
- Joined
- Jun 6, 2012
- Messages
- 10
Anyone suggest a good base antenna for listening to the Atlanta P25 system?
I'm on the southern side of the city, Hapeville area using a PSR-800 and cannot keep the T trunk indicator solid. For that matter, the signal strength bars are all over the place and I am often missing one side of transmissions or both. It takes somebody talking fairly long for the signal to lock.
And this is with one talkgroup programmed so it's not wandering off checking other channels.
The result is the same if using the stock antenna, the RS 800MHz duck antenna, the Laird NMO 150/450/800MHz mobile antenna, or an old 800/900/1900 Wilson data antenna. Two different PSR-800s as well.
If things are just right and I hold the radio pointing east or west, sometimes that T will stay solid and lo and behold the signals comes in just fine. Perfect.
TIA
TIA
