Can anyone recommend a good replacement antenna for BCD325.
Depends on what you are trying to listen to. For VHF and UHF, many people recommend the RH77CA:
For 800 MHz, the Remtronix 800B is the most common choice:
REM-842b BNC VHF/UHF/800 MHz REMTRONIX PORTABLE TRIBAND ANTENNA for Uniden Police Scanners by Bearcatwarehouse
www.bearcatwarehouse.com
(No endorsement of either retailer is implied.)
This assumes you will be using your scanner as a hand-held, not sitting somewhere permanently.
Note that the RH77CA is 15" long; if you are looking for something shorter the 800B still does better than the stock antenna on VHF and UHF.
